Question about MSI NX6600-TD256E NVIDIA GeForce, (256 MB) PCI Express Graphic Card
Sony xbr9 52 inch hdtv does not show full screen
I recently purchased a sony xbr9 52 inch hdtv. I connect to my pc using a vga cable connected to the nvidia nx6600 video card. boot up appears on screen in 19" area, windows xp graphic appears showing that its loading loading, then the screen goes black. A mouse appears and when click makes a noise but nothing else. Any ideas of what to do?
Get a e-gforce 8600 GT. also try right clicking on the desktop go to nvidia control panel change thos settings rather then regular xp settings.
Posted on Feb 17, 2010
  • 416 Answers
Have you tried the screen resolution settings on XP?
Posted on Jul 18, 2009
MY PC IS CONNECTED TO SONY BRAVIA KDL 32S5500 VIA 9 PIN VGA CABLE BOTH SIDES AND THE SCREEN STOP WITH INDICATION NO SYNC AND RESTORES AUTOMATICALLY. CAN SOMEONE HELP.KIND REGARDS
Change the cable with an other one and check. If any among the sync carrying wire inside the cable has a break, this kind of display can be.
Jul 01, 2013 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
How do I connect a PC to a LG50PG20 50" HDTV Plama?
You need a VGA cable (15 pin) connected from PC (monitor out) to the PC input on the HDTV (15 pin) this is for the video. For the audio, connect from PC to HDTV, audio cable, either 3.5mm from earphone out on PC to HDTV 3.5mm audio input (next to PC VGA input) and also be sure to set PC screen resolution to compatible output for HDTV like 1024 X 768 or 600 x 800 etc.
Select the PC input on the HDTV using TV remote.
Hope this helps.
Mar 06, 2011 | LG 50PG20 50 in. Plasma HDTV
Screen turns blue after Windows XP boot. It is
You cannot set your PC video resolution to 1920x1080 @60Hz?
Per user manual:
1. Set computer to a resolution supported by your HDTV (see Preset PC Resolutions). If your
computer supports it, we recommend 1920x1080 @60Hz.
2. Turn off the power to your HDTV and Computer.
3. Connect the VGA cable from your computer to the RGB PC jack on your HDTV.
4. Connect the 1/8-inch audio cable from your computer to the RGB PC Audio jack on your HDTV.
This step is optional and only needed to transmit audio from the computer through the TV.
5. Turn on the power to your HDTV and computer.
6. Select RGB using the INPUT button on the remote control or side of your HDTV.
Note: Refer to your PC computer user manual for more information about the video output requirements.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Sep 07, 2010 | Vizio VM230XVT 23 in. TV
Trying to connect my tv to my iMac using HDDB15 VGA pc mon rep c
pretend that the tv is an additional screen from your computer directly connected to the left of your computer screen. open something and drag it to the left and it should transfer onto the tv. HOW DO YOU GET SOUND
Jan 06, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
How do I connect my Sony viao to my philips LCD
If your PC has a DVI port( ihope u have one) purchase a DVI cable and connect it to your TVs DVI port
DVI port
dvi cable
If your tv has no DVI port and only VGA port buy a vga cable and dvi to vga converter and connect to pc and use it
vga cable
you can also get a svideo to avi converter cable and use it to connect to your tv
svideo converter
Nov 27, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
How do I connect my sony vaio vgn-fs920 to a tv?
As far as I know I need:
1) to purchase that VGA - S-Video Adapter ?
2) to purchase S-Video Cable itself ?
3) to purchase something like audio AV cables as well ?
Does anybody know where I can buy VGA - S-Video Cable (without Adapters) if it's possible and DO I NEED TO BUY AUDIO CABLE IF I'M GOING TO CONNECT THRU S-VIDEO?
May 14, 2009 | Sony VAIO VGN-FS920 Notebook
No sound and picture not full screen when connected to pc
if you have your tv connected to your pc with a vga cable, you will not get sound, since the vga does not carry sounds, only pictures. to change the settings on your pc to make full you will have to change your resolution size on your pc in your control panel
Apr 05, 2009 | RCA L26W11 26 in. HD-Ready LCD Television
Want to connect my Sony vaio VGN-A250 to Sharp 19'' LCD TV
Your laptop will have a VGA output or possibly a S-video out. For the VGA you'll need a standard VGA cable. Plug the cable in to your laptop and the PC input of your TV. If your TV does not have PC input it may have a DVI input. IF it does you can use a VGA/DVI adapter to plug it in. If it doesn't have a DVI input you can use the S-Video output on your laptop with a standard S-video cable. After the connection to your TV is made you will have to toggle alternate display by pressing and holding your [Fn] key and pressing F4, or F5, or another F# key. It's the one that looks like a TV screen. Press once to turn on output, press again to turn off your laptop screen, press again to go back to laptop screen only
Feb 10, 2009 | Sony VAIO A250 Notebook
Lenovo T60 interfacing with Vizio HDTV using RGB cable
The X1400 supports Full-HD resolution. Full-HD/True-hd (1920x1080)
The best output would be via DVI but you are limited with the VGA port.
I would purchase a Grand Hi-Wire PC to HDTV converter from www.globalcomputer.com. Item # G126-1036 @ $139.99
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 04, 2008 | Computers & Internet
MSI NX6600-TD256E NVIDIA GeForce, (256 MB) PCI Express Graphic Card Logo
677 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
