Question about Briggs & Stratton Garden
I have a poulan lawn tractor with a 18 hp briggs and stratton single cylinder engine. When I start the engine cold it starts fine then after 10 minutes it starts to smoke heavily and shortly after that it stalls. I also took the sparkplug out and it was so fouled with cakes of deposits on it I was surprised it ran. any ideas
  • 130 Answers
Eather the beather or the rings are bad
Posted on Jul 18, 2009
I have a charging problem with JD L155c lawn tractor. The battery is new and the voltage to the battery is 12 volts. Not enough to charge the battery. How do I check the ac voltage & what should the...
There are several possible Mowers of the "L" 155 versions.
John Deere LA155 garden tractor lawn mower. These stopped being made in 2010 (they started production in 2009, and so enjoyed a run of 2 years on the assembly lines). The JD LA155 is powered by a Briggs and Stratton 2 cylinder, V twin engine. This engine is 0.656 liters (40 cubic inches) in size and produces 22 hp.
1998 - 2001 LT Series
John Deere LT155 Engine: Kohler 1-cyl gasoline
2006-2006 L155c, This series was produced only in 2006.
Briggs & Stratton gasoline, 2-cylinder air-cooled, 724 cc [44.2ci ], 25 hp
Model 445777-0168E Code 021125YC, these are the engine numbers from a 25 hp twin cylinder, B&S.
Notes on these engines from parts supplier ereplacementparts.com:
Briggs and Stratton 445777-0231-E1 Engine: The proper flywheel part number and/or the alternator magnet size will determine the alternator type or output.
This 25 hp engine has 3 different possible alternators, standard circuit, dual circuit, tri-circuit. I would need the exact engine model numbers in order to precisely answer your question. Often mower models have choices for the engine they come with. In this situation the engine model is more important than the model of the mower.
Testing an alternator is fairly simple; all you need is a multimeter for testing.
  1. Disconnect connector from stator.
  2. Set multimeter for AC volts.
  3. Attach RED test lead to either pin on stator side of stator connector. (On single wire leads, attach RED test lead to the single pin.)
  4. On two wire lead models, attach Black test lead to the other pin. On single wire stator connectors attach the Black test lead to the engine ground.
  5. Prepare the lawn tractor for engine start (set parking brake, blade off, etc). Start engine and run at full throttle.
  6. Check output. Output for engines of this general size run in the 30 to 50 volt range. For instance the B&S V twin 22 hp AC output at full throttle is 30 Volts minimum. Other B&S on these machines spec 40 Volt minimum.
If your voltages are not in the manufacturers range, or non-existent, your stator is partly shorted or completely burnt out (open circuit). Either way you have to replace it.
A. In the picture is a single lead stator connector.
B. In the picture is a two wire stator connector.
Mar 15, 2015 | Garden
19.5 briges stratton how do we get to fuel pump it runns like out of gas
if it's a single cylinder Briggs and the gas tank is in front of the steering wheel and above the engine it wont have one. It's gravity feed. next time it starts to run out of gas, loosen the gas cap to see if this helps. if not then check the fuel lines. then suspect a possible fuel shut off solenoid issue... next time, you should give us the engine numbers
Sep 11, 2014 | Electrolux Home Products PB195H42LT...
What is the compression lbs for a 18 hp brigg/stratton intek engine
Not sure where to get compression pounds for this, but let me refer you to the Briggs website for detailed product specs and power curves.
Intek can be twin or single sylinder.
For Twin....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-series-v-twin
For single....the are in 1/2 HP ratings but the link is below....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-with-xrd-single-cylinder
If further detail is required, I will need the model type and trim found on the valve cover.
Aug 18, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What is the torque sequence on a 18 hp. v twin motor briggs and stratton motor
If your talking about the cylinder head bolts. I don't know the exact sequence but I was a truck mechanic for forty years and went by the rule of thumb to start in the center and work towards the ends. That way you avoid a buckling o9f the head.
Jun 16, 2014 | Craftsman 42" Briggs Stratton 20 hp Gas...
16 HP briggs and stratton poulan severe flooding
The carb is not closing down properly. You will need to either rebuild the carb or just replace it. Basically the float is staying open after you shut the machine down. Please rate
Jun 04, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Poulan Lawn Tractor 42" 14.5 hp Model 733-864 How do you remove the rear wheel to fix flat tire?
I need the diagram for a drive belt for a 42'' lawn tractor - 14.5 hp Can ANY ONE help me?
May 21, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
2005 Poulan PD17542LT Lawn tractor, It starts fine but after cutting my front yard (20-30min) it dies, it will start up but dies in a few sec. If I let it set and cool off I can get 20=30 min till it gose...
Normal maintenance been applied to this rider ? Filters, lube, cleanings ? This sounds like an electrical issue (component hot), or a vacuum in the fuel tank. Next time it 'stops' open the fuel tank up and listen to any air 'whooshing' in.
Jun 22, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
POULAN 42" 19HP RIDING LAWN MOWER
42 inch poulan belt broke on mower deck diagram to replace new belt
Jun 14, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Garden Logo
391 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
