Question about Canon Digital Rebel XT / EOS 350D Digital Camera with EF-S 17-85mm IS Lens
When I take a picture,half of the image is black.I have Rebol Eos XT, 8 megapixels.Some other times the picture will not take and I receive an "error 99". Is there something I can do, or does it need repair?
  • 1 more comment
  • jblanchar514 Jul 17, 2009
    I really did not understand his "my point ofview" comments, I think it needs service but can not understand why. I didn't get his explanation. Maybe I'm just ignorant!
    i've tried that, cleaning the contacts. camera works sometimes ,if i don't get a error 99. but when it does work, half of the picture turns out black. what can cause this?
    i understand about the contacts,but what causes half a black picture
    Top Expert:
  • Canon Master
  • 78,919 Answers
THERE IS NOTHING EXTERNAL THAT IS CAUSING THIS PROBLEM, IT IS MOST LIKELY A FAILED IC CIRCUIT INSIDE THE CAMERA, CANON DOESN'T SELL PARTS OR TECHNICAL MATERIAL TO THE PUBLIC, U WILL NEED TO SEND IT TO AN AUTHORIZED FACTORY REPAIR STATION, CONTACT CANON WEB SITE FOR REPAIR FACILITIES IN YOUR AREA.
Posted on Jul 17, 2009
  • 145 Answers
Error 99 on your camera indicates that there is a potential electrical problem involving the contacts of the camera. If you're not comfortable with potential repair or extensive cleaning of the machine, I would recommend calling the toll-free customer service number was noted in your user's manual for the unit.
Here is an easy cleaning solution that may clear up the problem:
Start by removing the lens. This will reveal the gold-colors contacts along both the camera base and where the lens connects with it. Gently clean these contacts with an unused pencil eraser. This will remove any particular that may be preventing these contacts from making a good connection and tossing you that error. As a note: when cleaning the unit, try to hold the camera in such a way that dirt will fall away from the camera and not back into the base or the lens.
  • 3,230 Answers
From service manual -
Err 99:
DESCRIPTION: This error occurs if there is an internal malfunction detected during the camera's self-checking procedure that's executed before every attempted exposure. This is somewhat similar to the flashing 'BC' warning that occasionally appears on Canon cameras.
REMEDIAL MEASURE: Try releasing the error by turning the main power switch OFF and then back ON. If this does not solve the problem, have the camera examined by a qualified service technician.
as my point of view -
ERR99 (error 99) is a Canon common tips, Generally speaking, ERR99 by contact lens or aperture failure caused by cable faults, which aperture the most common cable fault.
There is a Canon lens aperture is responsible for transmitting data cable soft, which is often in a cable shrinkage or stretching of the movement, and therefore are prone to fracture. After fracture can still use the lens, but the data does not pass, so can only use the maximum aperture photography, shooting with the other aperture ERR99 there will be failures, even if the depth of field preview function is also impossible to enforce.
Fault occurs, the camera moves half of the reflective plate that is stopped, the viewfinder can not see things darken. Camera LCD display ERR 99, and can not be a normal shutdown, remove the battery to be re-fitted to a normal boot.
Compared in terms of contact lens failure is not a lot of cleaning to remove the lens and then fitted with some contacts, and basic troubleshooting can. The cable fault is not possible to clear the fault of their own.
Good Luck!!
Thanks
After charging the battery and the green light says its charged. I put it into my camera and it doesn't turn on
Do you have another battery you can try? The battery should be charged, must have a dead camera if that is the case.
Jan 08, 2016 | Cannon EOS Rebel XT 8 Megapixel Digital...
Why is cannon rebel reading busy trying to load photo's to computer?
Check for bent or broken CF pins. This model also has a screw that always comes loose and may have shorted out part of the main circuit. Neither of these problems are consumer repairable, and I would suggest you seek a local repair shop.
Sep 07, 2014 | Cannon EOS Rebel XT 8 Megapixel Digital...
When taking a picture with my REBEL EOS the image display only shows the top half and the bottom portion is black. When I download the images they only show the top portion that was seen in the image...
This can be either a mirror or shutter problem. Take off the lens and fire off a few shots while you look inside...you may be able to spot the problem. I don't think you will be able to fix it but a repair facility can.
Sep 10, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Date on pictures taken and movie shooting on canon eos 400d
The EOS Digital Rebel, EOS Digital Rebel XT and EOS Digital Rebel XTi do not support stamping the date and time on the image.
It is not possible to record the date and time as part of the image at the time the picture is taken. However, the date and time is captured in the EXIF information of the image at the point of capture. It is possible to print the image with the date and time via printing software. Please see the documentation for the software package that you use for printing images for the proper procedure.
Apr 06, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Cmaera turn on/off
If you have used the camera a lot in that time frame then I would try a new battery first.
Jan 30, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Only half the image apears other half is black
well your sub-mirror is broken inside of the camera, i had the same problem, it just happens by itself after extended use of the camera, and it is not a means for recall by canon so you have to deal with it yourself.
this website can fix it for $130 and they will replace it with a metal piece so it doesn't happen again(original piece is weak plastic)
Oct 23, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Blurred football pictures
low light means the shutter stays open longer to capture the image.   Try changing exposure settings.
Sep 30, 2006 | Canon Digital Rebel XT / EOS 350D Digital...
Canon Digital Rebel XT / EOS 350D Digital Camera with EF-S 17-85mm IS Lens Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
