SOURCE: Timex Indiglo Acqua watch
For analog Acqua watches adjust date when month has less than 31 days:
3-Position Crown: Pull crown to "MIDDLE" position and turn CLOCKWISE or
COUNTERCLOCKWISE until correct date appears.
2-Position Crown: Pull crown to "OUT" position and turn CLOCKWISE until date
changes (approx.1:00 a.m.). Then turn COUNTERCLOCKWISE to 7:30 p.m. Repeat until correct date appears.
SOURCE: Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
SOURCE: how to set up ladies roxy digital watch
I found users instructions on roxy website at:
http://www.roxy.com/search/index.jsp?f=Taxonomy%2FROXY%2F2818169&categoryId=2818071&f=Taxonomy%2FROXY%2F2818071&fbc=1&fbn=Taxonomy|Watches&fbx=0
We were able to program our watch completely!!!
If you look on the back of the watch that you bought on the metal plate, it tells you the style. Ours was the Roxy 70's digital watch, and I found specific instructions at (even if this is not your style, the instructions may work):
http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf
SOURCE: just bought the Timex T5E291 marathon watch but
For setting instructions on all Timex watches go to Timex.com and download your manual.
Holding down the mode button will put you in set mode. You can then cycle through the fields and set the watch using the srt and rst buttons.
SOURCE: I have a Timex analog Indiglo watch and need to change the date
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals.Rate me, please.
