Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Wireless key pad and remote openers for the cars work intermittently have tried re-learning
    President:
  • 3,197 Answers
Your remotes and your keypad are small transmitters that send a signal to the receiver. If all your units are intermittent then it is the receiver that is bad. The receiver is part of the logic board.
Posted on Jul 17, 2009
I recently bought a house which has a craftsman 1/2 HP garage door opener. The garage door opener works fine using the wall mounted pad and also the numeric key pad, but not with the remote that came with...
If you didn't, try programming the remote this way.
Press and hold the button on the remote and then press and immediately release the smart/learn button on the motor unit. If this doesn't work you need to make sure you have the correct remote for the model opener you have. Your model number doesn't bring any results from Sears Parts.com.
Nov 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Keymaster Remote Pad does not reprogram The instructions say to type in my code, hold down zero, then press ENTER. The opener lights are supposed to flash but they don't. I've tried proceeding to enter...
Try it this way.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Nov 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Key pad not working. Garage door will open with
I'm confused about the battery you replaced inside the garage but you can try programming the keypad just to see.
Locate the smart/learn button on the back of the motor unit near where all those white wires go. Press and immediately release it and then walk over and key in your 4 digit code and press enter. If this doesn't work and you know the battery inside the keypad is good, you have a bad keypad.
Mar 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Changed code on the wireless chamberlain security key pad
Does it work from wall button? Hit learn button for 10 seconds. Hit again for 1 second and code keypad.Opener lights should blink 2x. Hit learn again for a second and hit button on a remote (Any button you chose). Again, lights should blink. Now should work. Repeat for any other remotes.
Jul 24, 2009 | Chamberlain 950CB Remote Control
Programing remote for a chamberlain liftmaster
Try this. Press and hold the smart/learn button for 6 seconds. This will erase everything from its memory. Now press and hold the button on one of your remotes while you press and immediately release the smart/learn button. Do this for each remote.
Find the model number for your opener. It will start with 139. Check to make sure you have the correct keypad. There are several models and the wrong ones will cause the problem you have.
May 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster key pad opens door with a single number punch
You are using a universal keypad and usually the 0 button is "enter" look up directions for the brand keypad you are using
Jan 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wireless Keypad wont allow use of other door openers
hit learn button for 10 seconds. now nothing will work except wired buttons. Hit learn for 1 second and put in yur 4 digit keypad code and hit enter, light on motor will blink twice. hit learn again for 1 second and push button on remote. again bulb will blink. continue pushing learn for 1 second and adding another remote.
Dec 26, 2008 | Sears Craftsman LiftMaster Chamberlain...
Programming remotes for garage door
sounds like you are doing keypad ok. is battery good. as far as homelink in car. follow directions for rolling code/security plus.
Dec 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftman garge door opener changing code on key pad
having all the remotes you want programed with you, find learn button on back of opener. hold button until little light goes out- no remote will work now, with each remote Press learn button once,Press big button on remote-light bulb on opener will blink on/off if bulb is working-do this each hand held-keyless is same way, put you 4 #'s in HOLD enter button-light bulb blinks on/off you have 15 sec. for each time you hit the learn button. also best to start off with new 9 volt battery before you start programing
Aug 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
268 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
