Question about Thermador SC272T Electric Double Oven
Thermador model sc272t oven 2 doors have dim display
Clock has dim display, oven works but we can not see any dispay settings like bake temp etc etc. open the front panel but can't tell if the display unit has any knob to increase brightness, or display board needs to be replaced. Thanks Zeff
  • Anonymous Dec 12, 2007
    Called Thermador service. Refered us to a repair out fit.
  • 213 Answers
There is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Posted on Nov 19, 2007
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Smeg pyrolitic oven is setting an alarm off on clock after we set the required temp it will start to heat up then the alarm goes off if not quick enough to reset clock, it then locks the oven door
in cleaning a pyrolitic oven is suppose to lock the oven door , this is a safety feature due to fact that oven gets up much higher in temp than a normal oven , the heated air it produces if let out would flash burn anything in front of it to ashes (people,pets,rugs,etc.) the clock doubles as your display window to see what temp oven is at , there should be a clock selection to see current time of day even if oven is in use , and last but not least , it has a delay cleaning start feature , you can set it to come on and clean it's self , Id recommend not to use this feature for safety reasons (I don't think the mfg thought that feature out too much )
the door should remain locked till oven temp is below a preset minimum safe temp ,id not force it open for safety reasons
Sep 28, 2015 | Smeg Ovens
I need a lower oven relay board for a thermador oven model sc272t
http://www.repairclinic.com/Model-SC272T-ID-200480-Parts
I am assuming the parts are for the USA.
Oct 05, 2011 | Thermador Ovens
The actual temperature of my oven does not agree with what it says on the digital readout in the clock area. I have been told that you can adjust the reading of the clock, but I cannot find the service...
Press bake and set temp. to highest setting on some it's 500 on others it's 550 aftef setting to highest bake setting. Press and hold bake button until 00 is displayed,use up/down arrows to adjust in 5 degree incriments to plus/minus 35 dergees . ONce you've adjusted it push cancel/off button and you adjustment will be stored even if power loss and clock went out.
If your temp is more than 35 degrees off the clock needs to be replaced
Aug 16, 2011 | Ovens
Experienced recent power outage in my neighborhood. When power came back on, the display on my Bosch Oven HBL5035 now reads "F03 Err". Tried unplugging, but can't get rid of error code and...
sounds like a power surge occurred when power came on and blew out something on the main board. Try looking up the model and model number online and you can find the owners manual then look up the section that tells what the code means. Try unplugging it and leave unplugged for an hour. then plug it in and see if this helps.
Dec 12, 2017 | Bosch HBL5035AUC Stainless Steel Electric...
Oven digital lighted display is dim
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Temp/clock display faided
its the display theat is fading away. I've haad meter's do the same thing after awhile and there's nothing you or I can do. Thanks for using Fixya
Dec 23, 2008 | Thermador SC302T Electric Double Oven
Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Dec 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
The electric control panel
dimming of the control panel is only rectified by replcing the display board/clock assy.
Nov 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Thermador SC272T Electric Double Oven Logo
1,035 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
