Question about Health & Beauty
I need the wiring diagram for the alan bradley contact/relay 100-c 16*400 ser.B to the sunal profi 3200 tanning bed
  • 158 Answers
Http://sunalparts.com/view_product.aspx?id=230 This is the website you can order the manual from. The manual contains schematics(wiring diagram) for you model. I can not find a free manual. I hope you are able to fix it. Take care and be careful. Feel free to ask me any questions you may have in the future.
Posted on Jul 17, 2009
I have a mark i tanning bed with a token timer need wiring diagram please for tanning bed
tanning beds are no longer acceptable because they are a proven source of melanoma cancers with a high death rate of users
They concentrate UV rays that are the main cause of the cancer
Now that you still want to promote your own demise from cancer, have a electrician check the wiring out as you are not qualified to do that and simply put the power wire in to the time on to the power put wire to the timer and feel free to burn your self to death
In this country tanning beds are declared illegal and they cannot be sold , modified or imported because of the extreme problem with cancers . All tanning salons have thrown them in the junk heap
Feb 25, 2016 | Health & Beauty
Tan america 3200 vip bed. Could you show me a diagram for wiring
consider this ---tan beds are the major source of melanoma cancers after sun burn
melanoma cancers are the highest cause of deaths as they are not found until too late
consider this--- is fixing this machine worth killing yourself for a tan
if you don't care then go google to the manufacturer and download the diagram if it is available.
Jun 25, 2015 | Cars & Trucks
Sunal tanning bed m# X144459200 In need of wiring diagram if possible The problem im having is when you power the bed all I get is a loud buzzing sound coming from the relay/contactor there is 116 volts...
The buzzing sound indicates a problem with the relay itself. It is a simple device whose purpose is to take a small amount of electricity ( like turning your timer switch on) which activates a small electromagnet coil, which then pulls down a metal contact bar which closes a switch to activate a major power consumer ( like the bank of lights on the tan bed).
The reason to do this is so you don't have like 3000 watts or more of power passing thru your timer switch which would require much beefier wiring and controls. SO by using a relay, the relay uses a small amount of power to flip a switch on the major circuit.
The relay buzzing sounds like either the coil in the relay is shorted out (the heat sometimes melts the insulation on the wires in the coil), and the short is taking away enough power from the relay magnet coil that it can't pull down the switch activation bar to switch on the bed.
If you have a voltmeter you can measure the voltage in the activated circuit that powers the bulbs. The wires should be the bigger gauge ones. If you are getting low voltage or no voltage in the secondary circuit (that is the circuit with high amps that runs the bulbs and fans) that is a good indicator the relay is bad .
If oyu know your way around basic electricity, you can isolate one of the ballasts that feed some light bulbs and hook a 110V power source to that ballast and see if some of those lights come on. If they do that is further confirmation the relay is bad and you may need to order a new one
Jan 27, 2015 | Heating & Cooling
1986 sca wolff 328sl tanning bed wont stay running
Consult manufacturer. You can track that down online. You may have a over-temp switch inside the bed. If so, then either the switch is bad or the bed is getting too hot. Have a trained technician to check voltage going to bed, if voltage is wrong that can cause bed to overheat. Make sure all fans are running, replace any fan that is not running. Clean all dust out of bed with vacuum and brush while you have it open.
Dec 15, 2012 | Wolff Sunvision Pro 24S Tanning Bed
Wiring diagram for sunquest pro 24 tanning bed
I do not have a diagram, but the contactors are really simple. You have 2 power switches on top of contactor and 2 wires going to the coil. There should be 4 larger wires on top, 2 in and 2 out.
If any of the crimp-on wire fasteners are blackened, then have a trained technician to replace the fastener. If bed comes on when pushing down on contactor with a plastic ink pen, then check the timer by turning on the timer and checking the voltage at the Main Relay Coil. If no voltage, then the timer is bad.
Jul 31, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Health & Beauty Logo
401 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
