Question about Car Audio & Video
I have a caliber 2007 with stock stereo and one spekear need to be replace but i opened it and it look to small on wats i have a 50w 4oms speaker and the stok speasker is size 15wats 4 oms can i still instll the bigger one wit no problem stereo has 66 wats out power
    Genius:
  • 1,114 Answers
Yes , you can replace the 15 watt speaker with the 50 watt speaker. The impedance of both speakers (4ohms) is the same , so that's a match. Actually, the 50 watt speaker may sound a bit better at higher volume, because it will not distort as much as the 15 watt speaker. Hope this helps...
Posted on Jul 17, 2009
I just bought some Performance teknique ICBM 500W and installed them and have a panasonic CQ-RX100U 50w x 4 stereo, its on a 91' ford explorer with a factory amp but not sure if connected. when i higher...
I had a 97 explorer came factory with a JBL system, and had a factory amplifier, I had to get rid of the factory amplifier and by pass it to get my new radio to work... my factory amp was in the very rear passenger under the plastic...... mine worked fine until I installed a new stereo (replaced stock one) and because my stereo didnt contain whatever it was to make the amplifier turn on, had to go bypass the amplifier and I unplugged everything I could find on it. Hope this may provide some clues if any
Nov 01, 2013 | Car Audio & Video
How To Wire Speakers
If you connect 1 16 ohm and 1 8 ohm in parallel (thing + to + and - to -) you will have about 5 ohms. You can then connect that to the 4 ohm terminals and you should be ok.
Dec 22, 2017 | Audio Players & Recorders
Hi r these good speakers?
Power Handling (Peak) 300W , Power Handling (Continuous) 150W , Frequency Response 25Hz-22Khz , Crossover Slope @ 4.5Khz 24Db/Octave , Efficiency (1 Watt/1 Meter) 93 Db , Impedance 4 Ohm .
what this means is that the speakers are designed for a car stereo alone, NOT stock stereo as it wont have enough power. See the one 50w x 4 ,, yeah its designed for those. All and all its not a bad deal.
Mar 31, 2011 | Planet Audio BB65PRO Car Speaker
I am getting a 50W x4 stereo head, i am wondering
Go to crutchfield dot com. Do a search for your car.
Apr 28, 2010 | Car Audio & Video
Need a wiring diagram for the stock stereo system in order to install after market unit
2007 Saturn Vue Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Dark Green
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Light N/A
Car Stereo Antenna Trigger Wire: White
Car Stereo Amp Trigger Wire: White
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Good luck and Happy New years.
Jan 04, 2010 | 2007 Saturn VUE FWD 4
Needing to locate the airbag control module '07 caliber
it is located behind the floor shifter in center console..under small piece of carpet
Jun 16, 2009 | 2007 Dodge Caliber SXT Sport Hatchback
TAKE OUT STERO
First you need to go to Schoche.com and Purchase a Small Blue Box that will let you convert the Audio wires into RCA Jacks. Got one for my 2007 Scion Xa Worked Great! You will still need to run your wires for the amp and Run RCA Cables to the Stereo. This box will cut into the Rear Speaker wires and still allow the Speakers to work while allowing you to Connect the RCA Cables for the Amp to the Box.
Jan 18, 2009 | 2005 Scion xB
04 sonata stereo wireing diagram
Battery ORANGE (+) RADIO HARNESS
Accesory YELLOW (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
LF Speaker (+) BROWN/WHITE
LF Speaker (-) BLACK/WHITE
RF Speaker (+) BROWN/YELLOW
RF Speaker (-) BLACK/YELLOW
LR Speaker (+) BROWN/RED
LR Speaker (-) BLACK/RED
RR Speaker (+) BROWN/WHITE
RR Speaker (-) BLACK/WHITE
Jan 01, 2009 | 2007 Hyundai Sonata Limited Sedan
Not sure how to do proper instalation for this product.
Usually
speakers are connected to.
On rear of case will be either 3 ports in line or 6 in a group each has a different color and unless you have multiple speakers which require to be set up from diagram that came with them
standard speakers plug into the Green port
Oct 13, 2008 | Inland ProSound 1000 Computer Speakers
Car Audio & Video Logo
43 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
