Question about General Electric Microwave Oven
The base thermostat TCO on the GE microwave has zero ohms resistance and the hood thermostat TCO has infinite resistance. What are they supposed to be and which one is defective? Also, isn't the high voltage diode supposed to conduct electricity in only one direction like all diodes? The microwave high voltage diode also has infinite resistance in both directions on an ohmmeter scale of 100,000. Thankyou for any help.
    President:
  • 2,777 Answers
I am quite certain that both are fine in that case, if it was defective it would be higher than 0 but lower than infinite.... sounds like it may be something else causing the problem.... let me know what you find / think.
Thanks
Tim
Posted on Jul 17, 2009
Ge spacemaker xl jvm1340WW error message e2
please make this step , use the multimeter, and fix it. Merry Christmas.
F2 Oven cavity thermistor closed Check oven thermistor for continuity. Replace if zero or infinite ohms.
Dec 17, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
F2 error message
please follow this step , use the multimeter and fix it. Merry Christmas.
Code F2 upper thermal sensor
please follow the steps use the VOM and test it. God bless you
F2: 3123f39f-6d87-4596-8303-294a18c6bec2.gifCheck oven thermistor for continuity. Replace if zero or infinite ohms.
May 27, 2013 | GE Microwave Ovens
Microwave VENT fan keeps running
I would say you replaced a good hood thermostat (or "TCO" / thermal cutout) with a new thermostat of the wrong type.
The oven cavity TCO and the magnetron TCO will read zero ohms continuity when tested.
They are "normally closed" devices.
But the hood vent exhaust fan's TCO is a "normally open" TCO or thermostat, so it should read open or "infinity" on a continuity check.
If the temperature under the microwave gets too high, the hood TCO opens, which turns on the vent fan until it cools back down.
I would bet that only your fuse was blown.
May 18, 2013 | Microwave Ovens
I have GE Advantium 120 SCB1001 Microwave Oven. It is plugged in, outlet has power, but nothing comes on at all.
There are TCOs (thermal cutouts) which also can fail or blow, resulting in "no power" conditions.
All but one of them should be accessible without taking the oven from the wall.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The full service manual is here.
You can find helpful exploded views and order GE parts here.
BUT there is one TCO which has thinner wires of a color other than black or white. This is the hood TCO and should read "open" or "infinite" which is correct.
All other TCOs should read shorted or virtually zero ohms on a continuity test, as should the fuse.
The cavity TCO is only accessible by removing the oven from the wall, then taking off its outer cover.
When taking the oven from the wall, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Jun 07, 2012 | GE Advantium 120 Convection/Microwave Oven
Hotpoint rvm1435 microwave: seemingly no power (no lights work, no buttons work, etc); however a voltage tester shows electricity inside the unit. I tried replacing the fuse, but that was not it...any...
In addition to the fuse, the safety devices which will render the oven dead during a fault condition are the bottom TCO and the cavity TCO.
The TCOs (thermal cutouts) have thick black wires connected to them, and they should both read "closed" or zero ohms when you do a continuity check on them.
Do not confuse the hood TCO, which has thinner red and blue wires connected to it and which are supposed to normally read "open" or infinity. If the hood TCO were bad, the hood vent exhaust fan would run all the time.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Aug 24, 2011 | Hotpoint RVM1435 Microwave Oven
My fan cannot be turned off on my ge advantium microwave convection oven
The service manual with installation instructions is here:
http://www.microwavedisplay.com/advantium_sca1000_sca1001_sm.pdf
You may have an open hood TCO (aka thermal cutout / thermostat). It should read normally zero ohms when measured.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
But if you recently had trouble with your cooktop lights, the control circuit board may be damaged.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid with a one-year guarantee.
Sep 08, 2010 | GE Advantium 120 Convection/Microwave Oven
My GE 1650 stopped heating. What can be the problem? Would it be cheaper to fix it or replace it?
The microwave oven high voltage network is what generates the microwaves that heat your food. It is usually comprised of these four basic components:
1. Magnetron (WB27X10429)
2. HV transformer (WB27X10254)
3. HV Diode (WB27X1160)
4. HV Capacitor (WB27X10240)
In most cases these heat related problems are caused by a bad magentron. The magnetron is the main component of your high voltage network, and it is also one of the most expensive parts. Worst case scenario, you're looking at $110.
Now, YOUR microwave oven also has a thermal cut-out (TCO) on the magnetron (part number WB27X10166). It is designed to protect the magnetron and other internal components from an overheat condition by blowing like a fuse. It could be that your TCO is blown. A resistance check with the component removed should read zero ohms if good. Best case scenario if this part is bad is about $21 to replace.
You can view an exploded view diagram of your microwave oven at pcappliancerepair.com. I have already given you all the part numbers. The magnetron is listed as item 73. The TCO is item 77. I'm not guaranteeing these to be the cause of your problem, but I will tell you these parts fail the majority of the time.
So...I've given you some options to consider. I'm not sure how much a new microwave will cost, but it may be worth your while to repair this one (especially if the TCO is the only problem).
If you have any questions, please let me know. I hope this helps you.
Jul 29, 2009 | GE JVM1650 1000 Watts Microwave Oven
New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes Failure
Code
Condition Check/Repair F1 Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms F2 Shorted thermal sensor, will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking Check oven temperature sensor for continuity. Replace if zero or infinite ohms
Note: It will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted or open. F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds Replace key panel (touch pad) F4 Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor F5 Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds Replace humidity sensor F6 Shorted temperature probe, will occur if temperature probe is detected as shorted continuously over 5 seconds Replace temperature probe ProbEe Open temperature probe, will occur if temperature probe is detected open, or not plugged into the receptacle If probe is plugged in and "ProbE" is on display check continuity of the probe with an ohm meter. If zero or infinite ohms, replace it
Feb 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
General Electric Microwave Oven Logo
64 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
