I notice there is an He Chlorox now that is advertised for the low suds washers...is this o.k. for my Asko 11505?
    Problem Solver:
  • 10 Answers
The He Bleach is sortof a marketing gimic. Its usally just a lower concentration of chorline. Since He washers use significtly less water during any section of the cycle Ie between 4-8 gallons some people can over concentrate bleach into water. As long as use follow the directions on your user manual for bleach and common residential kind is fine. I don't really recommend bleach tbh. Its corrsosive and and concentraion produces fumes which oxidize washers.
Posted on Jul 18, 2009
How long should wash cycles be? mine have gotten longer
Not an UNCOMMON complaint Rosemary Stein,
On the new machines "suds-sensors" control the "efficiency" of your machine...
If you check you OWNERS MANUAL I'm pretty sure
You need to run good grade "HE" detergent...
The reason being the "suds-sensors" will get messed up with BARGAIN detergents & become MORE IN-EFFICIENT.
Contemporary wisdom says "If you stop now and run some cleaner in your machine you can avoid costly serve charges".
Hope this helps!
May 06, 2016 | Asko W6021 Front Load Washer
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
Feb 12, 2013 | Asko W6461 Front Load Washer
My ASko washer machine will not start up, all I hear is a short humm when I press the start button. I took the cover off and noticed the control board has a burned chip on it. There is also a resistor with...
Sounds like the control board is fried. If you have gotten it open here is a link for a new board:
http://www.superiorapplianceparts.com/shop/asko-washer-control-board/?q=/shop/category/washer/asko/
Good luck! And make sure the thing is unplugged before you work on it!
Joseph
Apr 04, 2011 | Asko W6021 Front Load Washer
What is the partion insert for the washing powder container for?
Welcome to FixYa.
That is the Liquid detergent partition...P/N 8061633. ( part number )
**This from ASKO...
Because ASKO washers use less water than conventional top-loading washers, you need less detergent and fabric softener. We recommend that you use a low-sudsing powder detergent only, preferably a high-efficiency (HE) detergent designed specifically for front-loading washers.
**(Liquid detergents tend to suds more, which make them more difficult to rinse out.)**
Detergent - The amount of detergent needed varies, depending on the detergent you use. For high-efficiency detergent specifically for front-loading washers, you should use the amounts recommended by the manufacturer.
Also, the amount of detergent needed can vary due to differences in water hardness. (Refer to the Use and Care Guide for more details.) If you choose to use a liquid detergent, start out with a very small amount, such as one or two tablespoons.
Hope that answers your question, let me know please.Thanks for choosing FixYa for your repair solutions today. Let me know if you need further assistance.
Please take a moment and rate the solution provided for you as well as a testimony if you feel it warranted.
Good luck.
Regards,
Macmarkus :)
Oct 22, 2010 | Asko W6021 Front Load Washer
I have an asko 11505 clothes washer. For some reason, it is not going through all of the spinning cycle, it spins for a short time, then stops abrutely. I cleaned the coin stop, cleaned out all water...
My Asko 11505 washer fills only a little water then shuts off. If I drain the washer with the drain hose from under the machine, then the machine will start up and fill enough water to fill the hose again, then shut off.
Oct 19, 2009 | Asko Washing Machines
Water level too low. clother wet. No water visible or suds. What is wrong.
Your expectations are based on top load washers.
Front load washers use only a very little water, and suds are an enemy. (HE soaps are designed to clean without suds. Suds are really for show and cause drag on the wash tub during spin.) If you start a load with no clothes, you will see that the water level never gets above a couple inches in the tub. That is the correct water level for front loading machines. PS. Because of the low water use, make sure you use very little soap. (one to two tablespoons per load only!)
Aug 12, 2009 | Frigidaire Affinity ATF7000E Front Load...
Suds in the floor...
are you using he detergent,,,or low suddsing detergent,,,i believe your putting to much detergent,,and not the right detergent,,,to test run a load with no soap,,and see if you get water on the floor..onthejob
Dec 29, 2008 | GE WBVH6240F Front Load Washer
The word "suds"
to much detergent...with theses unit you must use he or low suddsing detergent..take half the wet soapy clothes out then start unit..sud level must fall...
Dec 27, 2008 | Maytag MAH8700A Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
