Garden Logo
Penny Branson Posted on Jun 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The trimmer fs 45 will notfire thru the spark plug wire or spark plug
hvend
Level 1:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 65 Answers
  • Posted on Aug 03, 2016
hvend
Contributor
Level 1:
Cheetah:
Answers
65
Questions
0
Helped
57402
Points
91
These guys mean well, but someone without any testing equipment , can not do testing of coil and wires/plug with those instructions, unless you have a meter and know how to attach probes. Simply put, unscrew spark plug, put plug back in plug boot. Pull over the starter rope, with spark plug grounded , either on top of motor(metal) . Then try to observe the Blue spark at tip of plug. If it is to bright out, you can also put a small screwdriver (small enough to put to sparkplug electrode) and crank it over while holding the screwdriver. If you get a bit of shock from it, you know it is putting out . May not be the best spark, or it could be just enough to ignite the gas. Then you know the carb is not supplying any or enough gas , and will need carb cleaning with carb spray, or rebuilding, and possibly a new carb. Observe coil and see if the magnets have turned a shade of blue. That means they have lost their magnetic charge, and will have to change out the coil.
Jim flowers
Level 3:
  • Stihl Master 1,098 Answers
  • Posted on Jun 29, 2016
Jim flowers
Stihl Master
Level 3:
Answers
1098
Questions
Helped
359012
Points
2966
Try a new spark plug that one may be bad
Testimonial: "still no fire thru the wireor plug"
1 Related Answer
Anonymous
  • 148 Answers
  • Posted on Sep 26, 2009
SOURCE: stihl fs 45 ignition problem no spark
Disconnect the small spade terminal wires from the coil itself and test for spark. If you do not have spark replace coil. If you do have spark check those small wires for insulation damage and grounding. If wires are OK check kill switch.
NOTE: DO NOT START MACHINE with small wires unplugged! Only test for spark.
1helpful
2answers
Stihl fs 80 trimmer, replaced carb, air filter, spark plug, ignition coil. still doesn't start. Next? not getting spark from plug
Loosen coil screws, adjust coil to magneto flywheel magnets with a double sheet of common paper, tighten screws, so that paper will pull out without tearing. That will give you the best chance for a good spark, with all you have done. Pull spark plug out , put top of plug back in spark boot.......crank ovr with rope, and ground spark plug on top of motor(metal), observe the blue spark. If none, check the short wires for any breaks from coil to switch. You can open handle and take out switch, if nothing else works.....then try and start. The wires are just to break the ground, to turn off motor. Can choke motor to stop.
Stihl fs 38 weed eater no spark
change the spark plug and test it again if no spark still it may be a broken wire or the coil has gone bad.
2answers
Where do I find a free repair manual for Stihl FS 46
If you have a nice Stihl dealer he (or she) might be nice enought to print you the specific repair information that you may need but no place that I know of offers the complete manual for free.
1helpful
Stihl fs 45 ignition problem no spark
Sep 17, 2009 • Garden
Pull cord is out and wont return. unable to crank stilh fs 45 we
Could be several things including a broken return spring. If you are not experienced with these springs please take it to a reputable shop to avoid any personal injury.
Jun 09, 2009 • Garden
2helpful
Fs 45 power
check the exhaust port. stihl put a down sizing plug on it and it can clog up. it is easily removed with a socket and cleaned out
Top Stihl Garden Experts
Thomas Perkins
Thomas Perkins
Kardoc
ADMIN Andrew
ADMIN Andrew
Are you a Stihl Garden Expert? Answer questions, earn points and help others
