Question about Pride Mobility Products Health & Beauty
Pride elite traveller 4 a knock when driven coming from drive
  • frankstew332 Jul 25, 2009
    Thank you for your help,found a service centre by my home,took a hour and £17.00 problem fixed,drive shaft and bearing greased all o/k. Thanks again.
  • Pride Mobili... Master
  • 1,271 Answers
Sounds to me like the worm drive is slipping , this can happen when the worm drive small bearing is worn,
If you do take it a part , please take great care, the shaft from the motor will have a worm drive, two bearings on the worm drive,
Try to move the shaft within the bearings, I paid £10 for replacement bearings.
Please give me a update.
Posted on Jul 24, 2009
  • Heidi Millington
    Heidi Millington Sep 03, 2016
    Hi Robin
    Have a similar problem on a go go elite plus. Out of interest where did you purchase the part for the worm drive from?
My Pride GOGO scooter is stuck in drive and wont go into freewheel?
The park brake has got stuck, the brake needs to come off and be stripped down and cleaned, this will sort it.
Jul 25, 2014 | Pride Mobility Products GoGo Elite...
How do i remove the battery from my go go elite scooter..?
If it is like my Pride Go Go Traveler Elite scooter, what they don\'t tell you is that you need to give the battery a sharp jerk to make it release and come off the scooter. You can\'t just pull it strong and steady.
Apr 26, 2014 | Pride Mobility Products Go-Go Elite...
My scooter sounds like its knocking
under warranty contact the agent and have them sort it.
Aug 09, 2013 | Health & Beauty
Needing to replace free wheel mechanism go go elite traveler scooter
em, this is new to be , can you go into more detail of the actual problem ?
Nov 28, 2012 | Pride Go-Go Elite Traveller Plus HD...
My pride go go elite traveler 4 wheel stops randomly often with no beeps. I have replaced the throttle, the speed pot, the brake, and the batteries check out fine.
You may have a loose connection at one of the harnesses or connectors. If there are no codes you may have a bad controller or loose connection at the controller. Slow speed problems may be motor or motor brush problems you can diagnose by visual inspection or a voltmeter. Load test the new batteries and the charger output. Block it up and run it checking and knocking all the components until it quits. I have seen a dragging brake caused by a melted controller harness at the controller connector cause a similar problem. Hope this helps.
Aug 18, 2012 | Pride Go Go Elite Traveller Plus HD 4...
Wheels- knocking noise in the right wheel
Hi. If the knocking noise happens with each revolution of the wheel, it is probably the square key in the axle that drives the wheel. Remoce the wheel and wipe a light smear of grease on the axle and key where it fits inside the wheel. As the wheel normally rotates, the weight comes on to the key and off again, causing the noise. The grease allows it to move without making the noise. Sometimes also caused by a stone in the tread, but most likely to be a dry key.Good luck. Neil.
May 08, 2010 | Pride Mobility Products Go-Go Elite...
Trans/axle noise, slow to apply brakes, no available service information
This did not fix anything. However I have found that there is NO service infomation from Pride on these scooters. No shoes, nos shirt, NO SERVICE.
Aug 14, 2009 | Pride Mobility Products Go-Go Elite...
Health & Beauty Logo
327 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
