Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool Side by Side Fridge Not Cooling
I have a white 24.cf something or 25.cf something (I am not Home) White Whirlpool side by side fridge with icemaker. I purchased it in 1999 and was the model just below the one with the built in water filter, mine doesn't have the water filter. Anyway, The fan motor in the freezer went out causing the ice to start melting and icing up. I was away and caught it after a week or so of running this way. I replaced that and it ran fine for a month. Now the fridge isn't cooling. The fan is blowing air, but either the compressor is out or maybe a relay? It used to make a click sound and then it would turn on. I was home briefly and didn't spend too much time looking at it but didn't hear the click sound. I can pull the rear cover and feel if the compressor is running. The coils are clean. Is there a relay or a temp control or what? I know I need the exact model number, just not home now and found this thread thought I'd get a head start. Could the compressor have fail running for a week with the bad fan motor?
  • 2 more comments
  • itzmepete Nov 18, 2007
    I have NOT checked to see if the compressor is running now. I Can check when I get home.
  • IES1 Nov 22, 2007
    I may have same problem.
    Fridge stopped cooling last night. Ice melting.
    Compressor thermal limit is clicking. I don't think the compressor is running, but the fan is. Looking for troubleshooting sequence.
    Mfg: Whirlpool
    Model: ED25GWXFW00 SK2331597
    Mfg Date: 05-2000
  • itzmepete Dec 18, 2007
    Well, I jumped the relay and the thermal limit and it ran but popped my homes circuit breaker after a min. I checked the compressors fields and the starting field was open. Seems the compressor took a dump. Got a new one but haven't had it installed yet. Seems these compressors are all crap and the newer fridges break down even more than the older ones! Kinda dissappointed with whirlpool products in general.
    Jumped the relay and the thermal timer. The compressor ran, but felt the power cord getting warm and my homes circuit breaker popped. Seems the compressors starting circuit was open and the compressor was drawing too much current. So I got a new one and have yet to install it. I am dissappointed with whirlpool but heard that the new fridges are even worse! Seems all these new compressors are crap. Heard the Korean built fridges are great but I know for a fact that many high end LG's have issues with circuit borads going out and they cost $150 or more! They don't make it like they used to...
Refrigerator isnt cooling
Posted on Dec 19, 2007
  • kickaboo Dec 19, 2007
    i have a side by side and the refrige side isnt cooling but the freezer is fine
    i have a side by side and my freezer is fine but my refrigerator side is not cooling
I have a side by side and the refrigerator side is not cooling
Sounds like you've got it. These relays generally don't go but the exception proves the Murphy rule. Wish you luck on this one.
Posted on Dec 18, 2007
  • 833 Answers
Here's the sequence: First, the unit must be ice free. This happens after power down for about 2 days. If the compressor is clicking, power off for 15 minutes. While waiting....
Clean the condenser coils.
If a mechanical thermostat, does it click when you turn it from off?
Locate compressor in back of unit. Find largest pipe. Power on.
Pipe should frost over for about a minute and then either dry out or form ice on it. If frost stays, you need refrigerant.
If compressor is not running, it could be thermostat, defrost timer (find this little gem in the back of the refrigerator and turn the stub shaft about 1/3 way around...does this change anything?) If the timer is bad...replace it.
Compressors generally don't fail from long run cycles.
hope all this gets you somewhere.
Fridge is not cooling. lights are working. freeer is working
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Jul 24, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Refridgerator side stop working on whirlpool gold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer/Fridge not cold enough
check see if compressor on check control if on
Apr 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Just Purchased a Whirlpool Fridge Side-by-side?
it will start making ice within 24 hrs you should be able to get water out the door but it wont be cold but it takes 24 hr for the box to get cold and stabilized
Dec 28, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge not cooling 60 degrees
hi thanks for the question did you clean the coils at the back by the compressor if not clean the coils its very important try that thanks the appliance doc
Sep 25, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
MY FREEZER FREEZING AND FRIDGE IS NOT COLD ON MY BLACK SIDE BY SIDE WHIRLPOOL
hi thanks for the question i would check to see if the fan in your freezer is working that could be the problem make sure the back of the fridge is clean where the compressor is located also make sure no frost has built up in freezer thanks the appliance doc
Sep 22, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
368 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
