Question about Uniden SPH21DT (1 Channel) 2-Way Radio
How difficult is it to change freq in a sph21dt 2 way radio? Isn't it a simple plug in to a programmer?
    Problem Solver:
  • 14 Answers
You have to go to a Uniden dealer. They have the software, and the cables to reprogram the radio. You could buy the software and cables yourself if Uniden has them for sale. I bought 2 Yaesu FT-2800M's with the programming software and CAT cable (the software and cable cost $30) and found it a delightful and easy way to program the radios.
Longshorts.
Posted on Jul 24, 2009
On a baofeng uv-5ra. how do i change freqs. on channell mode? frequency mode works fine but it won't let me change the freqs. in channell mode. thanks.
You have to be in "VFO" mode. Your best bet on that extremely difficult to use radio, is to get "chirp" and the proper cable and program it via a computer. If you search on-line for "baofeng programming" you may find an alternate set of instructions. Your absolute best bet: throw that PoS away and get a Yaesu FT-60.
Dec 14, 2014 | Baofeng UV-5RA Dual Band Transceiver
I need help programming my baofeng 997s
To programme a repeater. VFO mode & curson on top line of display. Enter freq eg 147.250. Go menu button change settings like offset, tone. In menu delete channel required eg 000. In menu below that, choose mem channel now 000 & it saves receive freq.
Exit. press *SCN button so R appears on display. Save as 000 again but this time it stores TX freq. In other words, you save RX first, then exit.Add * so R appears in display second time round and save again TX freq. Go to channel mode and see it is in 000.
I might do a video to help people. Its the same process with UV5r and other Baofeng. Simplex you just save in one operation because TX is RX.
Aug 08, 2014 | Radio Communications
The freq counter stays lit at 10.625mnz the claifier knob or the channel selecter will not change the freq counter
This problem, really need to be on a bench to test.. FREE at any good cb shop, to tell you what is wrong.... But most times when a freq counter is not working. Either the crystal is bad, poorly soldered, or its not receiving an input signal. Best way to test is to have a second freq counter external inline using coax.. and check the output of the radio and see if it shows correct or wrong. If it is showing correct they you internal freq counter is messed up. and needs to be check for a bad crystal or solder joints. sometimes even the voltage regulators go bad.. If it is showing a wrong freq on external counter then check the radio's crystal and oscillator circuit. this too can be as simple as a cold solder joint. on the solder side check the small surface mount diode near the PLL, next to the PLL shielded covers. It is normally black these come loose often times too. If you need more help feel free to call or text for more help.
Jan 28, 2011 | Galaxy Radios DX-66V Base CB Radio
I have three walkie talkies... Motorala CLS 1110... 2 of them are on FREQ 3 and the other is on FREQ 2.... how to i change the one on FREQ 2 to FREQ 3???
With the radio turned OFF, hold in the PTT and the MON, while turning the radio on. Continue to hold the PTT and MON until the radio stops making noise. You are then in programming mode and can use the menu button to walk through the stages of programming. Use the PTT to change the settings, and the MENU to lock it in.
Dec 23, 2010 | Motorola CLS 1110 (1 Channel) 2-Way Radio
I have a new RCI 2995DX . that after 1-2 mounths it go's off frek
Have you herd it off freq? Do you have a freq counter? How do you know that the person that told you it sounds off freq don't have their receive off freq?
if its on a freq counter, and shows not off freq, then the radio is not off freq. There is some other problem.. Or no problem because if it is just some one else saying it, maybe they are just too picky.
Things that could cause your audio to change. If its in your mobile, diving around will make your audio sound different to people. Antenna or feed line problems. If there is a problem with your antenna or feed line, it could make your audio sound bad or off to some one else.
Also, if this unit has been modded, has the clarifier been unlocked? if so that will change your TX freq.
If the unit is new and nothing has been done to it, there should be no reason why it is off freq unless some one has done something to it.
Feb 24, 2010 | Cobra 29 LTD CB Radio
Is there a way to scan the entire freq range on a uniden BC60xlt-1?
The BC60XLT does not have a global search feature. In fact, this simple scanner has no search feature of any kind. Reception is limited to 10 user-programmable frequencies and 7 factory-programmed NOAA weather frequencies. If you need a manual for your scanner you can download it here:
http://www.uniden.com/pdf/BC60XLTom.pdf
Sep 20, 2009 | Uniden BC60XLT-1 Handheld Scanner
Motorola walkie
With the radio turned off, hold in the PTT and the Monitor button at the same time. Continue to hold these in while turning the radio on. Wait for the radio to finish making sounds before releasing the PTT and monitor button. Then simply press the menu button to walk through programming each of the features. When you have reached the end of the user programmable features you will notice the radio has a different chirp to signal you are done. Then simply turn off the radio to leave programming mode.
Oct 26, 2008 | Motorola Walkie Talkie 2-Way Radio
V-800 trouble
when i turn on my radio it keeps beeping repeatly nothing else happens
Jul 29, 2007 | Vertex iTECH iQfive iQplus Yeasu--VX800...
Freq lock up
If you have programming cables and SW you can program a freq. in the center of the band,in slimplex. Question, can you read this radio?
Mar 01, 2007 | Motorola MT1000 Compatible 2 Way Radio...
Uniden SPH21DT (1 Channel) 2-Way Radio Logo
131 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
