Question about Vantec 1 Bay NexStar 3 USB 2.0 External Drive Case
Front light continuously blinking, but drive not detected
Brand new Vantec Nextar 3 enclosure with WD Green 1TB drive. The light on the enclosure blinks, but I can't feel the drive spin up. I have an older 200GB drive in an identical enclosure which works flawlessly. I haven't tested the drive internally yet, so it may be the drive or the new enclosure.
Actually, the light did stop blinking now after a few minutes. If the drive is on, I am unable to tell if it is spinning.
  • 158 Answers
SOURCE: Accessing
if you can get another hard drive and place it in the enclosure plug usb cable in then turn on the enclosure and see if this works if doesnt place it on another unit or pc and see if it accepts if it does then the usb drivers need to be re-installed goto my computer device manager and find usb it looks like a trident hilight this and click uninstall from menu list in properties then on the top of manager there will be a computer with a spyglass click on this and windows will find new devices let it continue then reboot then re-try enclosure if all goes well it will come up found new device. retry other hdd you first placed in enclosure if it dosen't feel hdd is turning the platters then get rid of hdd. hope this goes well
Posted on Aug 14, 2007
SOURCE: Hard Drive won't spin
I had this problem and I found out that plug & play wasn't enabled in the bios.
Posted on Jan 03, 2009
SOURCE: Vantec Nexstar 3 driver download
The Drivers are here :
1. <http://www.vantecusa.com/system/application/media/data_file/nst-360su.zip>
2. <http://www.vantecusa.com/system/application/media/data_file/nst-cx_drivers.zip>
Posted on Dec 11, 2010
  • 106 Answers
SOURCE: I have the Vantec NexStar
Before you can use the drive you may need to format it. Under my computer right click the drive and select format. the select your preferred file system(it doesn't matter witch unless you plan on holding files larger than 4 gigabytes, in witch case select NSTF). I hope that solved your problem.
Posted on Jun 17, 2011
jikbwevgwr
Vantec Nexstar 3 drivers can be found at driverupdate us.Take a look, and enjoy
Posted on Nov 02, 2014
Blinking light but not detected
Sub the cable if possible, if no! you may have a open winding in the hardware, not much you can do, the hard drives are sealed to keep dirt out and not made to be serviced.
Mar 17, 2012 | Western Digital 1TB WD ELEMENTS USB...
I seem to have some problem with the power. Its not turning on, blue light indicator not on in the WD 1TB external powered device. assuming the data is intact, but the power is the only issue. How can this...
Purchase an "empty" enclosure, for about $30, and "transplant" the disk-drive from inside your enclosure into the new enclosure (and new power-supply). All your files will be accessible.
Dec 16, 2010 | Western Digital My Book Essential 1TB...
Apr 04, 2010 | Vantec NexStar-3 External 3.5inch...
WD ELEMENTS 1TB and the power supply is blinking
You have a bad power supply. You can probably get a new adapter for it.
Dec 21, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
After I disconnect it from my pc for the first time, when i reconnect it it does not show up in MY COMPUTER. 1tb wd My bookessential edition
Western Digital Enclosures are known to have this issue due to the electronics inside. The Hard drive is most likely fine but the electronics that drive the enclosure are not that great.
If it is newly purchased you could return it on warranty or by a new enclosure but buy a good quality one.
Sep 24, 2009 | Western Digital My Book Essential 1TB...
Have installed ide hard drive but it isn't being recognized by the CPU and the light is strobing continually.
Did you install the IDE drive _inside_ the VANTEC external drive,
or did you install the IDE drive _inside_ your desktop computer?
Did you set the MA(ster) / SL(ave) / C(able)S(elect) drive to the correct position?
Sep 19, 2009 | Vantec NexStar-3 External 3.5inch...
Nexstar.3 Sata external drive woun't start
I also have the same problem. I bought a 500gb WD HDD and it worked great via USB for about 4 days, not the computer does not have it. i am running windows xp home. i can also hear the drive working and the blue light comes on, but it is delayed. When it was working correctly it came on instantly and the computer found it instantly.
May 19, 2008 | Vantec NexStar-3 External 3.5inch...
Nexstar External drive
If neither computers detect it, which is a good form of process of elimination, I would test the cable with a known working. I would then extract the drive from the enclosure. And try mounting into a desktop machine as a slave, or find another enclosure.
Oct 04, 2007 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Accessing
Apr 20, 2007 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Vantec 1 Bay NexStar 3 USB 2.0 External Drive Case Logo
783 people viewed this question
Top Vantec Computers & Internet Experts
Willem.
Willem.
Piyal Perera
Piyal Perera
David Payne
David Payne
Are you a Vantec Computer and Internet Expert? Answer questions, earn points and help others
