Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
SOURCE: blank screen but it has sound, when i turn on
Your fly back, horizontal is in good condition but the possible fault is in the deflection coils or the deflection correction , pin correction section or the hirizontal width coils.
Please check them one by one as they are found along the sides of the flyback sections. check the continuity of the horizontal coils, it can also be a leak/burnt coils that can cause this problem.
SOURCE: i troubled samsung tv the horizontal transistro was exceed heat
It is because the flyback is drawing to much current and it needs replace, and if it still drwing tomuch current,you could have a bad picture tube.
In most Samsung models, this transistor is fitted without a heat sink. When replacing it, the exact replacement number should be replaced.
SOURCE: problem horizontal output transistor overheating that cause transistor burnt.
Check and replace the deflection yoke. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
