Question about Tippmann 98 Custom Act Paintball Gun
Cannot adjust velocity
I have a Tippmann 98 Custom ACT Platinum series. The velocity is stuck at 330 fps, and turning the velocity screw will not change the speed. The marker has been in it's case since the last time it was used at a tourney - 11 months ago. I use C02 as my gas source.
The only modification added to the marker is a Cyclone Feed system, which works fine.
I have stripped, cleaned and re-oiled the marker, and it functions fine, but the velocity problem remains.
Any ideas? Thanks.
- M
  • 4 Answers
Please see below page 8 for picture of what I am talking about.
On page 8 in the middle left side is a picture of the internal vale parts.
When you pull the valve out on the back side is a little o ring that can be taken out using an o ring pick. Make sure to watch the way the parts come out and look for any rust, also broken o rings if the valve is stuck open this will allow the maximum of air to pass. Most of time is this part that is messed up. You can by the valve in one unit this is the best option.
But the first thing is to check the valve and all the parts. Lube it up and re install it.
http://www.tippmann.com/pdfs/manuals/98Custom_Manual.pdf
Posted on Aug 10, 2009
How do you test a tippman velocity...and how you set it...
Posted on Oct 10, 2010
  • Joe  A
    Joe A Mar 15, 2011
    You can go to a paintaball shop and ask them to use their Chrono to set your velocity.
    You can buy, it's what I did, a handheld chrono and set your gun yourself, when you
    have the time, make adjustments and come back and do it agian, without bothering anyone.
    This is what I bought but you can get them for a little less if you look around.
    http://www.punisherspb.com/sports-sensor...
How to set velocity on tippnan 98 custom
There is a velocity adjuster on the left side of the body, just below and to the right of the "N" in "TIPPMANN."
In order to adjust the velocity you need to be in a place where it is safe and legal to fire your marker (paintball field, with all bystanders protected by netting or paintball goggles.) You will need a chronograph and a 3/16-inch hex wrench.
The adjuster is a screw that blocks the gas flow from the valve to the bolt. If you screw it in (clockwise) it blocks more of the gas, so your velocity goes down. If you screw it out (anti-clockwise) it blocks less gas, so the velocity goes up.
Just take a shot over the chronograph to check your velocity, adjust and check again until you get it where you want it. Most paintball fields limit velocity to 285 feet per second. Never go above 300 feet per second, as velocities above that are unsafe (beyond paintball goggle ratings and can cause damage and infection on skin due to the heavy impact.)
It is important to test and adjust the velocity before each day of play, and even multiple times during the day as weather changes, because it is affected by temperature.
Jan 19, 2013 | Tippmann 98 Custom Act Paintball Gun
How do I adjust accuracy, I think it involves the screw on the left side.
Accuracy is not adjustable with the screw on the side of the gun, that screw would be the velocity screw and should not be played with unless chronographing the gun to avoid setting it at unsafe velocities.
If you'd like better accuracy there are 2 upgrades you can make. #1 is higher grade paint. The more round and smooth the balls are, the more consistent and tighter the grouping will be. #2 is barrel. The closer the bore matches the paint, the more consistent and tighter the grouping will be also.
May 31, 2011 | Tippmann 98 Custom Act Paintball Gun
Just installed a shoulder stock on a 98 tippmann......velocity is really low.why?
There could be a 2 reasons. The spring guide could be missing or your new stock just has different tolerances and you will need a spring kit.
Spring kits found here.
If the spring guide is missing and lost you can find it here.
Apr 18, 2011 | Tippmann 98 Custom Act Paintball Gun
I have a used custom 98 ACT platinum. When i fire it , it goes full auto. My speed is at 270 fps.What do i do?
Buy a oil for a few dollars made specifically for paintball. Put a few drops in the ASA(where the tank screws in) screw the tank in and try to fire it about 10 times. If the gun still goes FA or sputters, I highly recommend having it serviced by a local pro shop or Tippmann.
Mar 29, 2011 | Tippmann 98 Custom Act Paintball Gun
Just bought a tippmann 98 act took it home went to test and it still broke like everyother ball. Is it the balls or possibily to much veloicity? does it make a difference co2 or compressed air?
The velocity adjustment is probably way too high.
This causes too much propellant to enter the firing chamber.
There should be an Allen screw on the side of the gun where
you can adjust the velocity. Try backing the screw out a turn and see what happens.
Here is your owners manual to help you.
http://www.paintballadvisor.com/manuals/Tippmann%2098c%20manual.pdf
CO2 is very hard on O-rings so if you can use air you are better off.
I use an A-5, Autocockers, Smart Parts Ions and more.
Mar 06, 2011 | Tippmann 98 Custom Act Paintball Gun
Inconsistent velocity, and my velocity adjuster doesn't seem to be working
This is caused when a gun needs cleaning and-or O-rings are worn.
Tear down the gun and clean the lube with the special paintball gun oils
and reassemble. See if it is better. CO2 is terrible for paintball guns.
Go with HPA (High Pressure Air, aka Nitrogen) and this will help.
Feb 16, 2011 | Tippmann 98 Custom Act Paintball Gun
My Tippmann 98 Custom ACT will not fire higher than 190 fps regardless of how I adjust my velocity screw. Do I need a new power tube set up?
Well, the power tube probably isn't the problem. I'd make sure your marker is clean, and lubed with a good oil made for paintball.
Next, inspect the spring. Any kind of kink or damage will affect performance.
Also, make sure you're testing it with a full tank.. don't let low air pressure skew your diagnostics.
Play hard, play safe, play with honor!
8^)
Aug 17, 2010 | Tippmann 98 Custom Act Paintball Gun
How to change the volocity of the tippmann 98 cutom platnuim series
I have the exact same gun. Looking at the gun, barrel facing left. You'll see the word Tippmann. Just below and slightly right of the end of that word you will see a allen head screw. Using and allen wrench turn that screw. If you wish to raise the velocity, tighten the screw. If you wish to slow the balls down, loosen the screw (bring it out, but not too far.) The faster the paint balls go though, they have a tendency to burst (but not usually) or the big thing with mine, is they get more back spin, and they travel UP, making them also go further. If they go to slow, they are pretty inaccurate. I find my optimum performance, when the allen screw is flush with the plastic on the outside of the weapon. Hope this helps!
\\Seth\\
Oct 10, 2009 | Tippmann 98 Custom Act Paintball Gun
Air leak in 98 platinum
First you will need to know exactly the point where is liking from. I suggest you the powertube out and connected directly to the line so you can see what part is failing. After that there is no o-rings or anything involved so you would have to replace the part. It could be the line the powertube, or the valve. Here is a link to the manual in case you may not have it and a place where you can find parts for you 98 Custom.
-http://www.tippmann.com/pdfs/manuals/98%20Custom%20&%20Pro%20Manual%20Combined%20ACT.pdf
-http://www.tippmannparts.com/
Oct 08, 2009 | Tippmann 98 Custom Act Paintball Gun
Velocity stuck at 330 fps
No O-rings are used to change volocity on Tippmann Markers. The velocity screw is on the left side and is turned clockwise to decrease and CCW to increase velocity. Typically if you turn the screw in till it stops then turn it back 2 turns the gun will shoot about 280FPS.
Aug 11, 2009 | Tippmann 98 Custom Act Paintball Gun
Tippmann 98 Custom Act Paintball Gun Logo
727 people viewed this question
Top Tippmann Sport & Outdoor - Others Experts
spank61
Tom Chichester
Are you a Tippmann Sport and Outdoor - Other Expert? Answer questions, earn points and help others
