Memorex MLTD2622 26 in. LCD TV TV/DVD Combo
Problem for Memorex MLTD2622 26 in. LCD TV TV/DVD Combo
Turned TV on with remote, circular indicator went
By mvt3 on Jul 17, 2009
Turned Memorex 26 inch 20801 TV on with remote, circular indicator went from red to blue, turned around b/c no picturee or sound and nothing. No red or blue circle. No pix. Turned off power strip and back on...still nothing. Wall plug good. Tv less than a year old.
Best Solution
posted on Jul 18, 2009
Very Helpful)
stonephoenix
Rank: Guru
Rating: 91%, 630 votes
Please call Memorex customer service at 800-919-3647.
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If the TV is less than one year from the date of purchase, it is still under warranty. Call the number above so that you can have the unit repaired.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Comments:
Jul 22, 2009
- If the TV is less than one year old, it is still under warranty with Memorex. Please call 800-919-3647
so you can be set up for warranty repair.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 06, 2009
Not Rated)
Whizman
Rank: Wiz
Rating: 84%, 22 votes
1) Check fuse on back panel next to power cord. Pull out cord and pop fuse holder out. On an ohmmeter, it should read 0(short)-that is a good fuse.
2) Check the fuse on power supply board next to power connector. It is soldered onto board.
3) Be careful with this step: With all boards screwed in place, plug in TV and then unplug it. Next take a Voltmeter set on 200 Volts and test large electrolytic cap in middle of board-should have @100-200 volts on it. Do not short the capacitor-big fireball flash explosion if you do!
If 1-3 test OK, then:
D10 is shorted. HER304 in middle of Power supply board near large electrolytic cap. Replace with same diode or Radio Shack 276-1144 3A 400PIV Diode. PLEASE BE CAREFUL WITH HIGH VOLTAGE PRESENT ON POWER SUPPLY BOARD. UNPLUG POWER CORD!!! OBSERVE PROPER POLARITY WHEN REPLACING DIODE-LOOK WHERE THE BAND IS.
Was this helpful?
Yes
No
Popular Solutions for Memorex MLTD2622 26 in. LCD TV
Questions and Unsolved Problems for Memorex MLTD2622 26 in. LCD TV
Do you recommend Memorex MLTD2622 26 in. LCD TV TV/DVD Combo?
Answer
Answer
the dvd not function and the tv can't connect whith the local channels!
Answer
Panasonic tv model #CT32SL14J I have no power in my tv. The outlet is good and I am not sure where... (More)
Answer
memorex sign comes on for one second then the screen shuts down but still has sound.
Answer
we bought a memorex tv/dvd in June 09. Our house had a flood in July in the part of the house where... (More)
Describe your Flat Panel Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
in , CA
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
