-   I have the same problem. It is the built-in laptop speakers and it happens when I try to use a CD or DVD. It is a new laptop I purchased in spring of 2008 and very lightly used.-   jspecking
Oct 06, 2008
-   my iHome every now and thenit makes a crackling noise
-   Guest
Apr 10, 2008
-   i have the same problem. the aspire speakers make a crackling noise. did you find a solution. i´m about to send it to acer so then can take a look at it. please anyone, let me know. thanks.-   itoxillano
Hi, Clet,
sometimes is problem with the fans or hot place, say...beside wall or microwaves.
Be advice that common static noise start on problems with mobo.(sometimes).check cables too. and clean according.
good luck
right click the speaker icon at the bottom right.
click 'sounds', then 'playback'.
double click 'realtek speakers'.
click 'levels', then at the bottom there is a slider saying 'internal subwoofer'.
slide this to 0.
click 'ok', then close all the windows.
The internal subwoofer is off, (but can be turned on again if you want), so the crackling should have stopped.
It worked for me...
the socket where the power adapter gets connected does not function properly. i have to pull the...
(More)
the socket where the power adapter gets connected does not function properly. i have to pull the adapter wire and make it tight to get the power...
i can only get mt speakers to work with media player and nothing else all my sounds are on max just...
(More)
i can only get mt speakers to work with media player and nothing else all my sounds are on max just cant get sound from them on any other program
The subwoofer is working but not the other 2 speakers. The speakers are all hooked up properly and...
(More)
The subwoofer is working but not the other 2 speakers. The speakers are all hooked up properly and have power. I have tried unplugging it all and reconnecting it and still no luck.
