Question about Insignia 19 in. Widescreen Flat-Panel LCD HDTV
I am trying to use my 32 inch Insignia HDTV as the display for my 13 inch macbook. I got an adapter for the vga, connected everything and turned then on. The display only shows one of my desktop pictures and doesn't show anything else. I want to use my macbook as a dvd player.
--==<[ DVI to VGA vs. DVI to HDMI ]>==-- Caleb, what you really want to do to get your Macbook working with the Insignia HDTV is to >RETURN< and exchange the DVI to VGA adapter for a DVI to HDMI adapter. This is assuming your hdtv has HDMI inputs (which I'm pretty sure all the insignia ones do! I own a 1080p 32" Insignia HDTV and it has 4 HDMI's). The reason you should exchange them is that DVI and HDMI are essentially the same connector (and a better connection than VGA), the only difference between DVI and HDMI is that HDMI additionaly contains two audio channel wires. HDMI (which is a smaller version of DVI) is a digital signal and will give you perfect picture quality compared to the analog 'pc vga' type connector you were converting it to with the adapter you described (not to mention it will probably just work immediately since there is intelligent 'handshaking' that goes on with an HDMI connection, so it will tell your HDTV what resolution to use rather than it having to guess....)
I am guessing by now you solved the problem since it was in June that you posted and it's now November as I write this, but I figured you're probably not the only one who tried hooking it up that way. And most people don't seem to realize that DVI and HDMI are essentially the same type of connection, just smaller, with audio added. So someone will most likely benefit from this posting =)
Best regards, -=VRMan3D=- http://www.vrman3d.com <- 3D Screensavers and in browser 3D Mac/PC gaming for free!
Posted on Nov 13, 2009
  • 110 Answers
The first thing would be to have your external display on, then turn on your mac. It should see the monitor and set it up automatically. I'm not a mac wizard but if that doesn't work, I know in the display section you can set it to mirror your image to the external display.
Posted on Jul 18, 2009
I'm trying to plug my laptop into a tv to display my desktop and I can't seem to do it. I got a vga adapter and cord that is plugged into both the tv and laptop. What am I doing wrong?
The 13" White MacBook 2.0GHz has a mini-DVI out port. The adapter you need is
Apple Mini DVI to VGA Adapter
On the TV side, more information is needed. You need to specify what ports on the TV you are using for your signal, and what kind of adapter cable you are using. I suspect this is the component or connection where your problem lies.
May 20, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Visco LCD TV VSC-32V3 32
Did you check the cabling correctly
May 20, 2008 | Televison & Video
Trouble connecting Insignia HDTV 19" to my macbook pro
One of the first things you may notice about your new big-screen HDTV is that it has more connections for video than your old TV ever dreamed about. It probably has two or three HDMI connections, maybe a DVI connector, a VGA connector, and at least one component video connection. And those are just the connections most commonly used for high definition.
It’s shame to let all those connections go to waste. Your Mac just happens to be sitting nearby; why not hook it up to your new HDTV? It's actually a pretty easy task. A few lucky souls won't even need an adapter; for the rest of us, at least one adapter will be necessary.
Pick the Right HDTV PortFor best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection.If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference.Mac Pro, MacBook Pro, Mac MiniMac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports.If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac.If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine.iMac, MacBookiMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection.Make the ConnectionOnce you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV.Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac.Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV.Over or UnderscanYou may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan.You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV.Time to Watch a MovieOnce you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
Feb 22, 2010 | Insignia 19 in. Widescreen Flat-Panel LCD...
Insignia 22'' LED HDTV screen resolution problem with VGA
This is more of an alternative than a solution... but I solved my problem by getting a dvi to hdmi adapter and connecting to my mac desktop via hdmi. Once I then turned off the overscan in the menu I got a perfect 1080p image. Hope this helps. :-)
Dec 20, 2009 | Insignia Televison & Video
Macbook pro VGA color display problem
Go into system preferences, click displays, and make sure your color status is set to millions not thousands.
Nov 17, 2009 | Apple MacBook Pro Laptop Computer with...
I have a video adaptor that connects to an S-video cable and then to my TV which is currently hooked up to my macbook laptop. When I try to connect the same adapter to a newer macbook, it fits the port,...
Yes. The S-video adapter is not supported on more recent MacBook computers -- those having NVIDIA graphics cards: MacBook (13-inch, Mid 2009) and MacBook (13-inch, Early 2009).
http://support.apple.com/kb/HT1562
Oct 23, 2009 | Apple Computers & Internet
Macbook 13" locks up when plugging in my 32" lcd hdtv using the hdmi adapters
I the macbook white might not support hdmi if the tv is new you could use vga
Sep 12, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I want to connect my macbook to my tv. Do I need
well you can do 1 of 2 things, if your tv has a vga input then its just straight forward if not what ii recommend is a vga to hdmi connector , or depending on the output of your macbook , its a mini dva to vga/hdmi what macbook do you have?
Jun 30, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Macbook recognizes dell projector, but not vice versa
Your Macbook should automaticaly find the best resolution, if everything was OK. Is there any HDMI input on the dell projector? What projector is it? Is there is an HDMI input, you can use a HDMI to mini DVI cable: better picture and sound than VGA, and will probably solve your problem
Jun 26, 2009 | Apple MacBook Pro Notebook
Insignia LCD TV won't recognize computer input...
Heres the dealyo.
Click start button
Click control panel
Click display
Click settings
adjust screen resolution (probably have to go down) until the tv displays your computer
if this did not work, you will have to adjust bit rate from 32 to 16. Fiddle with the settings until the magic happens.
You will not get any sound unless you use an audio jack plugged into t.v.
Im here all week
Insignia 19 in. Widescreen Flat-Panel LCD HDTV Logo
808 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
