Question about Cameras
My easy share ls443 will not retract the lens or close the shutter.
  • Cameras Master
  • 2,200 Answers
Hi
This problem is most often associated with batteries which are either poorly charged or alternatively not maintaining a proper charge.
You should also remove the batteries from the camera and ensure the contacts are clean both on the batteries and on the camera itself.
If this does not work there maybe a problem with the lens gearing mechanism which is often due to sand or debris getting into the lens gearing mechanism and causing the fault.
Here are a few fixes you can try with your camera - however if the replacing/cleaning batteries method does not work you will have to try these at your own risk I am afraid. There is a report with some Canons that if you turn the camera on whilst pressing and holding the set button this may have the effect or resetting the mechanism. However this only seems to work with some Canon models but certainly worth a try.
I have listed these in order of least likely to cause harm to your camere but as I say if the above advice fails use these at your own risk. Many of these fixes have been found to work though if you are careful. Fixes 1 to 5 are relatively unlikely to cause any other problems.
Fix 1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on.
Fix 2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix 3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix 4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix 5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
With Fix 6 and 7 there is a potential for damaging your camera in conducting the fix so take care when conducting the following two fixes.
Fix 6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix 7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. If all of these fail the camera will have to go for sevice repair to resolve the problem. I hope this helps. Please remember to rate my answer. Many Thanks.
Posted on Jul 17, 2009
Review windows is black, pictures are black
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 12, 2009 | Cameras
My Easy Share (Z730) is in the open position & will not close.
VERY COMMON WITH EASY SHARE. There are only a couple things you can really do. FIrst, try removing the memory card and try it. Than if that dosen't work. Try holding power button while gently wiggleing the zoom.
May 30, 2009 | Kodak EasyShare One Digital Camera
My son pulled out one of the shutters that opens and closes over the lens. The shutters no longer open all the way. The camera is brand new. How can I fix the rest of the shutters? Should I pull them...
You can pull off the other one if you want. To put it back in your basically going to have to take apart the camera. The "Shutters" on the outside is nothing more but to protect the lens will its in the camera. The actual shutter is inside the lens that open and closes very quickly when you take a picture.
Think of it this way, the shutter in the lens opens up to let in light that shows the image to the sensor behind the lens. Then it closes to "finish" capturing the light".
The "shutters" or "doors" on the outside do not move once you take a picture. They only close once the lens retract. (When the camera is turned off or idles)
Hope this has been helpful.
Mar 30, 2009 | Fuji J150w Digital Camera
My Kodak Easyshare LS443 is taking black pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Dec 15, 2008 | Kodak EasyShare LS443 Digital Camera
Kodak Easy Share V550
mine fell in water and now the lens retracted and won't shut and i have error #45lol
try charging your camera, if it hasn't been broken from the fall, hope it had a soft landing!
Feb 25, 2008 | Kodak EasyShare V550 Digital Camera
Kodak LS443 EasyShare camera
Hello friend....Please help me to find the problem with my Camera Kodak Easy share LS 443.....
The problem is.....When I want to do a picture....I dont see anything on the display......Just a black windows....But No problem to see any picture from the other Camera.
Thank you very much for your time.......
Nov 10, 2007 | Kodak EasyShare LS443 Digital Camera
Kodak ls443
#45 is a lens error code, very common problem with ls443, not much you can do, you will need to replace the whole lens assembly
Aug 22, 2007 | Kodak EasyShare LS443 Digital Camera
Error
lenz motor not worck or may jam
Apr 02, 2007 | Kodak EasyShare LS443 Digital Camera
Telescoping lens problem
Hi, Tosty I have had this problem for what seems like a couple of years now. I simply turn the camera on, pull the lens out with my fingernail a little, and then grab the OUTER telescoping ring and turn it gently counterclockwise until it locks into position. When you turn the camera off, turn the Outer ring gently CLOCKWISE and help it retract and turn off. I have been operating like this for quite a while. Now I have the dreaded "Black Screen" problem. If I'm reading the postings correctly, I think the internal shutter is locked closed and I need to take the camera apart (keeping track of all the tiny screws!!) and attempt to unlock the shutter. Good luck!
Aug 07, 2006 | Kodak EasyShare LS443 Digital Camera
Camera
hi try turning the camera on while its trying to move the shutter HELP it! just push the shutter to its place... idont push it to hard or you will make it worse if that wont work while starting it up give it a little slap on the bottom or on the side hope it helps good luck
Apr 09, 2006 | Kodak EasyShare LS443 Digital Camera
Cameras Logo
138 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
