Question about Amana Quiet Zone 12M12TA Air Conditioner
Amana Quiet Zone air conditioner 12m12ta
The operation indicator and timer indicator are flashing constantly... I tried unplugging and then plugging it back in no change. Your help would be very much appreciated.
  • 30 Answers
Try setting the Unit to run full out, set unit at 66* it maybe the lights flash to let you know the save ( power) is on ?. Otherwise look for the manual and troubleshooter page .
Posted on Jul 18, 2009
Red light flashing constantly and top of freezer not cold enough
SECOND suggestion... If it does have a DEFROST TIMER...
look very closely for for the timers CENTER SHAFT...
AFTER UNPLUGING from the AC OUTLET (hazardous voltages)... a dead timer can be moved (less than 1/4 turn) out of DEFROST CYCLE allowing the refrigerator to temporarily resume operation...
The "DEAD TIMER" can be replaced later to restore
frost-free (self-defrosting) convenience!
Comment me back if you need any other suggestions
PartSelect Appliance Parts and Repair Help
Find Your Appliance Parts Search Over 2 1 Million Appliance Parts
Appliance Parts 365
http://searspartsdirect.co/
Jan 16, 2016 | Refrigerators
MY FIJITSU inverter is not working correctly, the timer light is flashing continuously and the timer lights flashes 5 times can anyone help pleawe
fujitsu is a good brand.
try one of these two things:
Turn the unit off then on again. After that press test button on remote control (rear side) and look how many times now operation and timer LED flashes. Note that. Then press MANUAL/AUTO button on indoor unit until you hear 3 beeps from buzzer. That will erase error memory.
Switch off and than on unit and see if indication repeat or it is gone. If it is gone, keep using your unit.
If it is repeated post your notes here.
OR+++++++++++++++++++++FOR OTHER MODELS
5 x Operation flash and a constant Timer flash indicates an outdoor unit control error. With this code flashing on the indoor unit, you need to point the remote at the unit and push the test run button. The flash pattern will change to a continuously flashing Operation light and a number of flashes of the timer light which gives more detail on what the error is.
To get the unit to try to restart you need to push and hold the manual/auto button on the indoor unit for a few seconds then reset the mains power supply but leave it off for a minute or so for the unit to power down completely. If you are going to try this make sure you make a note of any error codes first if you have to get someone out to look at it, it will help them a lot.
Jan 05, 2015 | Inverter Heating & Cooling
Fan continues to run in the off position?
The contacts in the switch are welded shut (if this is a portable unit). On a central system, the fan relay contacts are welded shut.
Oct 06, 2013 | Amana Quiet Zone 12M12TA Air Conditioner
Tv will not stay on standby timer light flashing
On Sony the standby or red is for shutdown---
If you unplug the set and plug it back and turn it on and it repeats this look to see if the light is either constantly blinking or blinking a specific number of blinks---specific number would be an error code.
Apr 29, 2012 | Televison & Video
Not cool enough
What is the temp of the air copming out of it at this time depending on the room temp it shuld be about 15-20 degrees cooler than room temp
Jul 24, 2011 | Amana Quiet Zone 12M12TA Air Conditioner
How do I set my Woods N1506 timer?
According to another fixya answer posted December 4 2009:
SETTING NOMA N1506 TIMER
Plug in timer - The letter C will Flash
TO SET CURRENT TIME:
Press Time Button - It will advance to 1 a.m.
Continue pressing until right time to the nearest hour.
(NOTE: A dot at the bottom right corner of the display indicates P.M. hours).
TO SET ON AND OFF TIMES FOR TIMER OPERATIONS:
Press Mode button - Letter P will flash inviting you to set the program
Press Time button repeatedly until required staring time appears in the window. (starting time is now displayed).
Press Mode button again - the letter E now flashes.
Press time button repeatedly until required ending time appears in the window. (Note: a dot at the bottom right corner of the display indicates P.M.hours).
Press Mode button and the display returns to the current time.
Programming is now complete. You may now plug in whatever needs to be turned on. The device will turn on and off automatically every day at the times you have just selected.
TO REVIEW THE PROGRAM
Press time button - Displays successively, for 1-2 seconds each: P, starting hour and E, ending hour. Then returns to show the current time..
TO CHANGE YOUR PROGRAM
Unplug the timer, which will discontinue the current program. After 10 seconds, plug it in again and proceed to set current time. Then continue with the programming steps as above.
FOR MANUAL OVERRIDE
Pressing the Mode button at any time will turn on the devices plugged into the timer. The display will indicate the letter O. The devices will remain on until the ending time of the daily program. To return the timer to the automatic mode prior to that hour, press the Mode button again. The display will return to show the current time.
AFTER A POWER INTERRUPTION/FAILURE
The timer will return to displaying a flashing C and the devices plugged into it will be off.
Nov 23, 2010 | Woods Outdoor Lighting Timer
I need instructions for using my N1506 timer.
Plug in timer – The letter C will Flash
Press Time Button – It will advance to 1 a.m.
Press Mode button – Letter P will flash inviting you to set the program
Press Mode button again – the letter E now flashes.
Press time button – Displays successively, for 1-2 seconds each: P, starting hour and E, ending hour. Then returns to show the current time..
FOR MANUAL OVERRIDE
Dec 04, 2009 | Woods Hardware & Accessories
Water does not drain from my Amana quiet zone AC. It builds up inside, then causes rusty looking sedement to blow into my house. How/where is the water supposed to drain to the outside? Thank you, Bobbi
If this is a window unit it has to tilt a little to the back(outside) for the water to drain off the bottom back side. I am suspecting the unit is setting tilted toward the room a little. Look at that first. Hope I was of help to you!! Good luck!!
Nov 22, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Amana Quiet Zone 12M12TA Air Conditioner Logo
197 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
