Question about Toshiba TZ43V61 43" Rear Projection Television
Toshiba tz43v61 TV just died. No red light.
Toshiba tz43v61 TV just died. No red light. No power. Unplugged/plugged TV. Nothing. No sound, no image, no power.
  • Wong Jeff
    Wong Jeff Apr 23, 2017
    https://www.Abctay.com is an online shop ,
    We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
    TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
    LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
    touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
    Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.?
Does it have a power strip on the tv stand? if so plug the tv into a wall socket.my power strip went bad and the reset button did not work
Posted on Oct 24, 2009
SOURCE:
Re:toshiba 55h70 tv i unplugged the tv to paint. when i plugged back in a wk later i have no picture or sound. nothing. can't access the menu - completely dark screen. the red lite "on" button...
I would check the fuse on the main board. Check the Capacitors on the Power Supply board. Seeing that you unplugged it and replugged it in you might have bad caps that were weak to begin with. Please learn how to safely work on a TV before attempting . Even when a tv is unplugged it has enough power to kill you. Discharge all Capacitors first. make sure its unplugged of course.
Jan 06, 2011 | Toshiba 55H70 55" Rear Projection...
Red power button blinking but tv won't power on
chec your ic register diode and transistor.
aslo check poer supply waltage and earthing properly.
Oct 11, 2008 | Toshiba TZ50V61 50" Rear Projection...
Will not power up. Red power light only blinks.
If you have sound and no picture, it's time for a new lamp.
In the manual check under LED indication, It explains the blinking lights, unless your outside at night looking up!
May 03, 2010 | Toshiba TZ43V61 43" Rear Projection...
Redslight blinking have no picture
Have you replaced the lamp before? If not, I recommend you do it, since it may be what's causing this. There is power on the TV since you get the blinking light, so it's most probable the lamp.
Jul 31, 2009 | Toshiba TZ43V61 43" Rear Projection...
Toshiba tv will not turn on
I have a toshiba tv and it will not turn on. There is a flashing green light that comes on, but there is no picture or sound.
Oct 31, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
Toshiba TZ43V61 43 in. Rear Projection... Problem
Try unplugging unit for 5 minutes, then plug in and turn on. If this works, your power supply may be going. However it is more likely that the bulb is gone, you can replace it yourself, but make sure you get the right bulb for that unit and take care in the installation of it.Go to the manufacturers website and look up your model and find out how to inspect and remove the bulb.
Bulbs can run for 140 to $300 and can be found on EBAY
Sep 28, 2008 | Toshiba TZ43V61 43" Rear Projection...
Plugged in, worked, turn on later, did not work
First thing i would do would be to check convergance amp ics
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Toshiba 55H70 55" Rear Projection...
Toshiba TZ43V61 43" Rear Projection Television Logo
574 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
