Televison & Video Logo
s
stacey jackson Posted on Jun 26, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tv wont connect to the ps3 with a hdmi lead
I'm trying to connect the television to the play station 3 with a HDMI lead
Electro Med Services
Level 3:
  • Televison & ... Master 6,694 Answers
  • Posted on Jun 26, 2016
Level 3:
Answers
6694
Questions
Helped
1870099
Points
21433
Do one thing. Connect the HDMI to TV connect the power to PS3. The press and hold the power button on the Front panel of the PS3 for 4 seconds.Then follow the instructions on the screen. While you hold down the power button PS3 will reset all the setting and will let you choose the Video resolution.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
How to connect a play station 3 to tv?
Just plug it like a regular DVD player thru HDMI connection and then choose HDMI AV input from your TV to be able to see the screen. You can also use the TV as a monitor by using the S-Video or the VGA input and then put the audio of the PS3 to your Audio system or amplifier.
1helpful
Problems with HDMI. Screen goes 'blank' whilst playing game. TV claims to be not receiving any signal. play with HDMI cable at back of ps3 and picture returns... Is this my ps3 my HDMI cable or my...
I have the same problem but i changed my hdmi lead for a more expensive one from comet and its fine now! so proberly just a rubbish HDMI lead i bought mine on ebay for £2.99 :-( Not such a bargain.
1helpful
2answers
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
1helpful
2answers
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Playstation 3
Have both the AV cables and hdmi cables hooked up from the tv to the ps3. On the TV Menu goto the av station which is different from the HDMi station...From the ps3 menu screen gotot settings then to video and audio and select hdmi then back to the tv menu and select the hdmi station and the ps3 main menu should be seen and you are all set
4answers
PS3 to XBR1 HDMI
hey, im hopeing the tech will be able to sort it out for you, theres not much any of us can tell you what he couldnt tell you tomorrow so be patient.
if he doesnt get it sorted drop us a comment and il try to help you.
8helpful
7answers
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
1helpful
Hi I recently played my ps3 on my friends tv using an hdmi lead and all was fine. Now i have returned home and tried to play my ps3 without the hdmi lead and it wont work can you help please.
go back to your friends with your ps3 and change the tv settings on the ps3 back to scart output but also take your scart lead and have it plugged in at the same time. once you have selected scart output unplug the hdmi cable to make sure the settings are right. hope this helps you.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
