We now learn that its NOT the TCM
you heard some one say , it (rumor)
or say the coded looked it up forgot
that CMP,CKP and TCM are all different things
post the codes this time, all of them
connect scan tool
turn it on the ignition switch
scan it
the crank it
the start it
got more codes. post them.
Like P0340 , and like that....
if not , doing that, you will never find cause.
its like asking the roofer to fix the roof
but the toilet , leaks.
why not post symptoms first.??????????
did you know, that the PCM (engine) in limphome can cause low power, and seems like a bad trans?
did you know that the TCm can go to limphome
mode and do the same thing, (low power, skips a gears)
we scan first. then leap second.
The TCM i bet is NOT bad, and if that is true
as it is 99.5% of time, then finding it is just a waste of your time and ours.
facts.
i see now you did scan it and engine sputters
(misfires grossly)
but failed to post the DTC errors.
fail.
My car starts stuttering and straining when it gets to 3rd gear to the point I have to turn car off and crank it up again it jumps to drive then hesitate to drive it pulls slow I got a diagnostic test and it said TCM crankshaft position and tune up I did everything but the TCM my car still doing same thing I was told it was located inside my car by brake pedal
wrong name it told you a code, and you forgot the DTC code , correct.?
TCM and CMP are 2 diffr. things.
the TCM is the transmission brain.
the CMP is the sensor that is the precursor to spark and injection timing.
now you will ask where is my CMP.
or where is my CKP,
post the codes, and WIN, a WIN /WIN
you win
and we win not chasing wrong parts. see?
this is the 2 liter engine, right, used in USA cars, right, ??
and on that engine in this country, you dont want to have a bad CKP, ($$$$$$$$$$)
so not posting the code, makes getting answers wrong, and huge costs pulling and engine that dont need pulling.
CKP is behind the flywheel.
the CMP is at the end of left camshaft.
do not fiddle the CMP base or it will get worse.!!!
why not scan the PCM
then when it barfs out (dumps) lots of DTC errors
write them all down on paper and post them
all exactly as you see them.
verbatim... and win. a win/win.
P03xx??? and the like...
all of them ,
SOURCE: replacing the transmission range sensor Suzuki Reno
Nope, disconnect the battery before install and reconnect it when your done.
Testimonial: "Thank you so much!!"
SOURCE: Where is the oil filter
OIL FILTER LOCATION. LOOK LOWER FRONT OF ENGINE WHERE TIMING COVER IS.
SOURCE: where is the transmission control module located i...
where is the transmition control module in galant 2000
P0700 is the code
