Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Found usb device message
Hi all...i got a weird problem with my 320gb book..when i connect it to a usb,windows doesn't recognises it,instead i get a ''found a usb device '' message and it asks me to install the drivers for this device..which don't exist.
the last time i used it was a week ago and it worked fine
Help pls!thnx in advance!
  • 1 more comment
  • FIGO007 Nov 19, 2007
    Hi all...i got a problem with my 500gb book.. it fall about 70 cm in cool way when i connect it to a usb ,windows doesn't recognizes it, instead I get a ''found a sub device '' message and it & installed ready to use but the drive can’t be available , if I make restart and the WD is connected windows will be frozen from the begging & it can be continue until disconnect the hard .
  • lefteris Nov 19, 2007
    thnx for the help friend..
    I've tried the two first options with no luck :(
    I plugged it in another pc and it comes up with the same message...
    so I guess the problem is with the hard drive and not with my pc..
    and I can skip the re-formating
    Any other ideas maybe...?
  • lefteris Dec 10, 2007
    Hi guys...
    I found out what was the problem..
    I opened the external case in order to save the hdd and hopefully my data and what I found was that the hdd cables had moved slightly out of position,propably from a fall or a knock I hadn't even noticed.I pressed the back in and my book was back to normal..
    Hope this can help...
    PS:these sites have info about how to open the external case
    Problem Solver:
  • 10 Answers
There are drivers available for your book on the WD website...They are meant to be used with win98...If you're using XP the drivers it's asking for isn't for the book but probably the USB hub...
Things you could do by order of priority:
1) Re-install the driver for USB hub
2) Install those 98 drivers (won't do any harm)
2) Repair Win XP
3) Re- format your PC (I know it's extreme...but as a last resort you may want to consider it)
Good luck !
Posted on Nov 19, 2007
  • Incubus_DZ
    Incubus_DZ Nov 20, 2007
    It is strange, but one logical explanation would be a faulty USB cable....Replace the USB cable between the HD and the PC and let me know...
Hi i have an everio gz-mg 135 and when i connect it to my pc to back up files the message "usb device not recognised. One of the usb devices attached has malfunctioned. Windows does not recognise...
- Make sure you have been installed JVC driver on your PC - If your PC has multi ports USB, just try other ports to make connection - check your firewire, it may be malfunctioned . Try other USB cables
Jan 16, 2011 | JVC Everio GZ-MG130 Camcorder
I have a brand new WD 1TB My Book delivered today not recognised
Pleaes open the Device Manager and right click on the Yellow exclamation mark.
Now, click on update Driver and select Install from Advanced Location.
Type the Location as C:\Windows\inf and click on Ok.
The Driver should be installed now.
Jul 13, 2010 | Western Digital My Book Essential 1TB...
Apollo 320gb external hdd is not recognised by PC . USB is enabled and recognises other devices.
If the drive came with a disk and they usually do I would recommend you install the disk first and after the installation has been carried out you then try to connect your hard drive via your usb port. Good luck. If this doesn't work then there may be incompatibility issues. What version of windows are you using? Andrew
Jan 17, 2010 | HP Computers & Internet
Usb device not recognised
Is this the first time you connect your printer on that computer? This can be the USB port does not support a 2.0, or your data cable/printer cable is damage.
Hope this helps
Aug 29, 2009 | HP LaserJet 1020 Printer
WD My Book 1TB, not recognised by XP
I had this same problem, it worked then just stopped. So i bought a new USB card and that worked fine. But know all the old USB ports works aswel. Weird...
Sep 26, 2008 | Western Digital My Book Essential Edition...
Western digital my book 320gb not recognised
Try first disconnecting all USB ports and power plug for half an hour, this will get rid of eventual problems caused by electrostatic charges on usb channels.
If it does not work, this means that the virus has corrupted your Windows System, probably the root hub is defective.
In this case you will have to reinstall windows, either using recovery, from disk or partition, or using a Microsoft windows setup disk. Save all your data before reinstalling.
Jun 01, 2008 | Western Digital My Book Essential 320GB...
Not recognised malfunction
Sounds like your drive may be faulty with the rattling - if I were you I'd back up everything off it pretty quickly, then send the drive back to western Digital if under warranty. I wouldnt open it otherwise your warranty will almost certainly be void.
Mar 28, 2008 | Western Digital 320GB MyBook External USB...
Camera not detected by XP
Are there any settings in the camera's menu to tell it to switch to PC Mode?
Mar 12, 2008 | Canon Elura 65 Mini DV Digital Camcorder
USB connection is not recognised by computer
Where can I download the Panasonic video camera model no. VDR-D300 from the Internet?
Nov 14, 2007 | Panasonic VDR-D300 DVD Camcorder
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
734 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
