Air Conditioner seems to be working but the Blower Motor does not come on.
  • 8,220 Answers
Some units use a relay to change fan speeds.
Heat requires a slow speed while cool requires a faster speed, Take a LOOK
Posted on Jul 17, 2009
1999.5 Jetta TDI: Loss of acceleration at speed.
the turbo has no effect on blower motor performance. you may have a bad turbo but you may also have a bad blower motor or a low freon level on the a/c system.
May 28, 2012 | 2001 Volkswagen Jetta TDI
The air conditioner unit outside works fine but it does not blow any air in the house.When it wants to blow, it makes a humming sound only but no forced air movement. Also,how do I access the blower,...
On the Good man you need a 5/16 nut driver take the furnace panels off and the blower is in the bottom area. There are 2 screws up top that connect to the blower housing take those out. Everything else will be loose be careful with the wires they can be tricky to work around. But take your motor out throw it away and install your new blower motor and capacitor. Its a simple job really. If you replace the motor yourself you willl save over $300.00
Jul 06, 2011 | Goodman CKL49AR49 Air Conditioner
Hi, my air conditioner was working fine, blowing nice and cold air. I went to the store and when I got back in my car it wasn't blowing any air out hot or cold. Seems like the compressor kicks on, I...
Sounds like your blower motor when out, check voltage at the blower motor connector under the dash passenger side under dash, with key and blower on, if you have voltage blower motor out, also tap on it some time it will turn it on, but if it happens again you will have to replace it.
Jun 11, 2010 | 2005 Hyundai Santa Fe
The front heater/air conditioner blower stopped
First check the voltage at the front blower moter. If it has voltage then it may just need a new motor.
May 17, 2010 | 2001 Dodge Grand Caravan
The heater and air conditioner will not blow out any air
if the air started to work only on a few settings then the problem is your blower motor resistor if it just stopped all of a sudden then the blower motor is bad but the first thing i would check is the fuse. always check fuses first if you find a bad fuse for it and it pops rite after you put it in and turn the heater on then replace the blower motor
Jan 02, 2010 | 1999 Volkswagen Beetle
Fan won't come on.
First shut the power off then pull the blower out and try to spin the wheel if it spins freely then check the capacitor look for any swelling or dents and unless you know how to check it out, some AC parts stores may check it for you, but a lot of people just replace it first before the motor (it costs less usually around $5.00) if it's ok then the motor is probably bad and would need to be replaced.
Apr 23, 2009 | Fedders A6P09S2A Air Conditioner
2005 Toyota Tacoma Air Conditioner Not Working
Quick tip that might help. Under the glove box is the blower fan, check the plugs that run to it make sure they have a good connection. then give the blower fan a little tap, mine was just stuck. could have been from dust or something. Or a plug might have been loose.
Apr 12, 2009 | 2005 Toyota Tacoma
Air Conditioner Problem
I would use a multimeter and check if the voltage changes at the blower motor, as you turn up the blower speed on the controls. If it goes up, you need a blower motor. If not, the a/c amplifier.
Jan 19, 2009 | 1997 Lexus LS 400
Air conditioner
Turn off unit supply and check the blower wheel inside the indoor unit by rotating it manually by your finger if the blower wheel rotates freely then there is something wrong with your fan motor or fan motor capacitor. But if the blower wheel is not rotating freely try to check the fan motor for lubrication or some bushing dried of and no oil
Dec 10, 2007 | Heating & Cooling
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
