I recently tried the DIY service and repair manuals from a website and it actually helped me repair transmission problem in my jcb 3cx site-master. It would'nt move forward or reverse, engine was good both solenoids for forward and reverse worked, but still couldn't diagnose the problem.
I don't have much technical knowledge but I just followed it step-wise, and now it works perfect! covers wiring, diagrams, torque specs, PCV, everything
got it from www.reliable-store.com
I don't have much technical knowledge but I just followed it step-wise, and now it works perfect! covers wiring, codes, diagrams, torque specs, PCV, everything
Not sure for 98s. But you need to erase the codes to start. If the problem is still there, Check the wiring to the transmission. You need electrical diagrams.
If the transmission is not extremely low on fluid then there is but one reason for this, the transmission has failed and will need to be removed and rebuilt or replaced with a reman unit.
The two only causes I can think of for this IF it is an automatic is either low fluid or shifter alignment. Does the shifter align with the marks for all the forward gears? If you slowly go from park to drive, does reverse engage at any point?
If it is not fluid or shifter, then the transmission needs to be checked. Could be reverse gear or if lucky just the bands are not catching for reverse.
remove the battery and the black plasctic piece this will give you access to the shifter switch, verify that the connecters on the bottom of the shifter witch are still connected
