Question about Sony Playstation 3 (PS3) Console
Our PS3 controller keeps going to the right, refuses to go left and only sometimes goes up and down.
Did u try to turn it off then turn it back on dont touch it while u turn the machine on this may wrk if not ure controller proberly buggered
Posted on Jul 17, 2009
I have a fisher minute mount an older model with fixed controls. plow goes up and down but does not go left or right, sometimes with the control set for left or right it starts to go up ? where to sta
check the wiring connections on the plow solenoids to be sure they are correct, the second step is check the controller box, using a continuity check via multimeter set for DC voltage. I have an old western plow that had similar symptoms, and was the controller box.
Oct 19, 2014 | Cars & Trucks
Driver window/mirror controls not working correctly
sounds like a worn switch have it changed and yuo'll be less frustrated trying to get the mirror etc how u want it
Apr 22, 2014 | 2005 Cadillac STS
Ps3 controller manual
You plug in the usb cable to charge the controller and connect it to the ps3 for the first time. You use the left analog stick to move around the dashboard when the ps3 is turned on and the 'X' button to change settings, go to the online browser, playstation store, or start a game. You can back out by pressing 'O' or holding the 'PS' button, which allows you to change a controller number (say controller #1 to #2 with two controllers), turn off the system or turn off the controller. Press (not hold) the controller to look around the dashboard while in a game and select say "Quit Game', or go into settings and change something around to your liking. Every game also comes with the controls and for what the buttons are. (Stick on left is the, "Left Analog Stick," right is "Right Analog Stick," from right to left starting at the green triangle shaped button is the, "Triangle," "Circle," "X," and "Square," buttons. The four buttons on the left going in all directions is the D-pad, and the triggers on the back going from the top left to bottom left and top right to bottom right are, "L1," "L2," "R1," "R2").
Feb 05, 2013 | Sony PS3 DualShock3 Wireless Controller...
Why does my ps3 do this
You need to restore the file system.
Here is how to do it.
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode).
2. Put out your usb cable for the controller and the controller itself (do not connect yet).
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when t turns off.
4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button.
5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that.
6. After connecting the controller press PS button.
7. You are now in the recovery menu.
8. To fix the problem of corrupt data you can choose #3.
9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive.
10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
Jan 16, 2010 | Sony Playstation 3 (PS3) Console
Right analog on ps3 gets stuck on top left direction
the circular thing that lets it move freely probably cracked, making it harder to move. i had to buy a new controller because of this reason.
Dec 03, 2009 | Sony Playstation 3 (PS3) Console
My controller is original dualshock3,...the stick and the pad when i turn on the ps3 on the xmb menu it rapidly goes stuck to the left any ideas before i buy another ps3...HURRY!!! i won't hold much...
Have you tried using a different controller? Usually this is the problem, your PS3 controller's D-Pad is stuck on the left side or the responding piece beneath the D-Pad is being pressured down in some manner. I recommend trying a Different controller first before buying another PS3 ( get a cheap PS3 Arcade stick or something)
Nov 17, 2009 | Sony Wireless Controller for PS3
Ps3 wont go left
Probably the controller. Try using a friends on your PS3. If that doesn't work, I'm sorry and I won't be able to help you.
Sep 04, 2009 | Sony Playstation 3 (PS3) Console
My ps3 will turn and u can hear the sound but no picture?
Hold Down The Power Button For 20 Seconds
You Will Hear A Few Beeps But Don't Let Go Until You See A Picture
Cheers, Tristan
Jul 05, 2009 | Sony Playstation 3 (PS3) Console
PS3 Dualshock Does not Charge.
hi i had this problem my controller would not charge although my head set would useing the same usb cable .i brought a new controller and tried two usb leads it was no different .this is the silly bit go and buy a new genuine ps3 usb cable and and i promise you all your problems will be solved .i have no idea y the cables stop working with only the conroller but they do i hope this helps all you people pulling your hair out trust me this will work
May 10, 2009 | Sony Dual Shock 3 Controller for...
Sony Playstation 3 (PS3) Console Logo
1,662 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
