Question about Ovens
How do i stop the oven top from clicking?
The oven is clicking and I see sparks, is it safe to clean?
    Top Expert:
  • Ovens Master
  • 52,576 Answers
That is not the oven and it does not look dirty to me .
Posted on Jun 25, 2016
Oven ignitor intermittent spark, oven wont light, emits gas.
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Mar 13, 2015 | Ovens
I have a whirlpool range rf263lxtq the oven stays consent on what is wrong with it
Oven clicks as if it is relighting almost constantly.
· Old electric range ovens use a coil heating element called a resistive coil.
This is nothing more than an electrical wire encased in a sheath. They have flat black coils over rounded burner drip bowls that catch your drips and spills.
· The newer glass-ceramic cook top style element produces heat that radiates through the glass top to the cookware above.
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
ELECTRIC OVENS:
Feb 15, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Stoves Q720 GRF DO main oven ignitor clicks / sparks continuously
Might be the PC board, or it might just be the switch behind the oven knob - try disconnecting the wire leading to that switch and see if the clicking stops. If it does, the switch is bad. If not, suspect the electronics.
Aug 23, 2014 | Ovens
NATURAL GAS OVEN WONT COOK PROPERLY
ELECTRIC OVENS:
Apr 06, 2014 | Frigidaire Ovens
Frigidare gas oven wont ignite
ELECTRIC OVENS:
Feb 07, 2014 | Frigidaire Ovens
MY Jenn Air model WW2780W isn't coming on. When I click on the control panel it clicks then the display says 140 preheat on.. for about 30 seconds then it shuts off it has done it for awhile and it would...
I have the same double wall oven, and it will "turn on" and then shut off after about 30 seconds. The top oven stopped working 4 years, the bottom oven stopped working about 2 years ago. Both are doing the same thing. I'm interested in replacing the capacitors to see if that fixes the issue. There are 2 larger capacitors (1000uf 35v), and lots of smaller ones. Is it safe to assume it's the larger ones that need to be replaced? The only other 2 matching capacitors are very small (0.47uf 5v). I know this is an old thread but would appreciate any advice. Thanks!
Sep 27, 2013 | Jenn-Air Ovens
Heating element not working
When cleaning the oven you got to be very careful because there's a little piece of copper in the back it looks like a little copper wire with a bare copper wire on it that is usually a thermostat it's on the back wall of the appliance inside the oven now you have a heating element on top and bottom you said that one of them stopped workin now you have a heating element on top and bottom you said that one of them stop working when you were cleaning the oven could you may have hit it moved it enough to disconnect it at the connection that comes out of the back of the oven to the inside of the oven to the element check and see if the two wires coming out of the back of the inside to the element are disconnected usually it's a Phillips head screwdriver now if you broke one of those wires needs to be reattached before you do any kind of work on that element or anything you should always unplug your oven from the wall the electrical outlet unplug it to be safe now if your thermostat which is that wir thermostat which is that wire copper wire looking thing coming out and see me on the back wall of the inside of the oven it's on a clip if you moved or bent that in any way that could also cause you thermostat which is that wire copper wire looking thing coming out and ceiling on the back wall of the inside of the oven it's on a clip if you moved or bent that in any way that could also cause your temperature to be off you really don't want to have to touch that if you don't have to I hope that helped you be safe and good luck
Feb 18, 2018 | Kenmore 47722 / 47724 / 47729 Electric...
Electric range flashing "F1"
EOC is the Electronic Oven Control. if you have major sparks I would call a service tech because there is an underlying cause that needs a trained eye to be sure it is safe for you to use.
Jan 30, 2012 | Frigidaire Ovens
Whirlpool counter top gas stove electronic ignitor sparks all the time,had to unplug to make it stop
The spark ignitor has failed. Have it replaced and that should stop all the extra clicking. Hope this helps. Good luck.
Aug 27, 2009 | Whirlpool Ovens
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
48 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
