Question about Maytag M7DH65B2A Dehumidifier
Can the refill option be bypassed?
Refill light is on even though I never use the refill tank and the unit will not start. If I push the refill clip by hand it starts but dies when I remove my hand from the refill clip
After 3 min. of operation unit blows warm air.when turned of for 1 second and back on is o.k.for 3 min.
If it is an older unit, it may be low on Freon (they _do_ use freon). There is no way to refill a closed system. The only other possibility is a bad pressure switch, and again, it involves the type of appliance that nobody supplies parts for (and are usually not user serviceable anyway). Sorry. // Note: I considered not even replying with such a non-helpful answer, but I am certain of what I am saying and I don't want to see someone going crazy looking for a solution that has a high probability of not existing. // Sincerely, -Gregg
Aug 15, 2015 | Frigidaire Dehumidifier LAD704TDL
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
Can't get front grill off to clean coils even
Probably have some plastic clips on the inside, like a car dash or door cover..try using a standard screwdriver and lightly pry open could also slide off
Jul 24, 2011 | LG DH504E GoldStar Dehumidifier
The red indicator light just flashes when i turn the unit on. Whats wrong?
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Good luck.
Aug 12, 2010 | Kenmore 54351 Dehumidifier
The bucket full light blinks even though it is empty and there is "01" in the screen where the digital humidity level is indicated. Pushing the up or down arrow does not change the "01" number. Unit won't...
Take out the bucket and locate the bucket full switch inside the cabinet. Depress the switch and see if it comes on. If so, you may have to add a shim to the bucket or strap it in with a bungie cord as the bucket is jiggling and makes the unit think that it has been removed.
Jan 02, 2010 | Kenmore 54701 Dehumidifier
Unit will not run.
Error code 01 - unit has a sealed system leak; most warranties are 5 years.
Dec 30, 2009 | Kenmore 54701 Dehumidifier
No water collects in our LG LHD45ELY7 dehumidifier. Bucket is properly installed. I take off back plastic cover and notice the copper line out of pump compressor is only v. slightly cool (other line gets...
It can be recharged but you would first have to locate and fix the leak and then refill. Then add a schraeder valve and refill at the port till suction line is cold to touch and starts to sweat. That's it!
Sep 09, 2017 | LG LHD45EL Dehumidifier
Dem 10 Delonghi Dehumidifier not working
have you tried turning it to a higher setting ??
May 03, 2009 | Dehumidifiers
Delonghi DH400P Discharge Hose
I have the same problem on ocassion.
I just remove and reseat again , making sure the front of the tank is flush with the unit. sometimes a little more push in does the trick
Aug 11, 2008 | DeLonghi DE400P Dehumidifier
Maytag M7DH65B2A Dehumidifier Logo
146 people viewed this question
Top Maytag Dehumidifiers Experts
Steve Allison
Steve Allison
Bill Long
Sr. Pelo
Sr. Pelo
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
