Question about HP Pavilion dv9000 Motherboard
I have probelem with dv9000, when i shut the system full shutdown but after some time cpu fan start Rotating, any soulation plsss
  • 81 Answers
Pls try change ur power pack you know when yow shot ur system down, the power cable is still connected, so there is still power in it so now it is discharging power when its not surposed to, but if cant afford another power pack now alaways off it totally, i mean from the way socket or ups. thanks.
Posted on Jul 18, 2009
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
How can i tell if the fan on my vaio CS31S isnt working properly? It seems to speed up and down and the laptop shuts down? Is it te fan or could there be another reason for this shutdown? :-)
Try blowing out any dust from around the fan with compressed air. If the fan is turning on and off a lot, this could be normal, depending on your processor, but if the system just shuts down fully and randomly, it would be a heat issue. The CPU is overheating and the failsafe mechanism is to instantly shut your computer down. The only way to avoid this is to raise the CPU shutdown temp in the BIOS settings, or if you can access the CPU, remove it and apply new, quality thermal grease. Also, ensure the fan is operating correctly during use and dont block any air intake or exhaust ports.
Mar 08, 2011 | Sony CPU FAN CPU Fan
Sir, my sony vgn cs100E laptop fan is not working, i keep my laptop very clean, but now when i start windows the laptop automatically shutdown after 3 min processing. Fan is not working. what should i do?...
Hello Faiz
OK, the thing is, if the fan is not rotating at all, you will need to replace it. The problem related to the computer shutting down, is the fact that the CPU overheats, and then shuts down the computer to protect the system components.
SO, if the fan actually rotates, you will need to clean the fan from all the dust particles collected on it. If the fan does not rotate at all, you will need to replace the broken fan.
Hope this can be of help.
Kind regards
Andrea
Nov 28, 2010 | Sony CPU FAN CPU Fan
When turn on my computer after a seconds the system is shutting down.. i don't know what to do, is there a problem with the processor?
A overheating CPU will shutdown and won't start up again until the CPU has cooled down.
The overheating problem (ie. thermal shutdown) is most likely caused by a faulty CPU fan or dust clogging the CPU fan and heatsink.
Check the BIOS CPU fan speed could be set too low, check the fan speed/temperature setting.
If this problem is not fixed, then the CPU will eventually fail.
Check the fan to see if it spins freely, if not then replace the faulty fan.
If the fan and heatsink are cligged with dust, loosen and remove the dust and use a can of compress air to blow away the dust.
Sep 22, 2010 | Computers & Internet
Hp Pavilion dv9000 powers on, then shutdowns, and keeps repeating.
Try it without the battery inserted with the AC adapter.
Jan 04, 2010 | HP Computers & Internet
Pc shuts down ,reason cpu overheating
It seems to me that your pc is facing hardware problem.It is suggested that you contact local computer service to replace the faulty hardware..
Jul 25, 2009 | Computers & Internet
Cpu fan still running even the system was shutdown
Unplug your computer from the wall socket. Then the only power it will have is the battery that keeps the CMOS information. There will not be enough power for anything to run.
Don't forget to rate this solution.
Jan 19, 2009 | PC Chips P21G (881038000916) Motherboard
System shutdown
Systems that shut down after being powered on can point to an over heating of the CPU. Other factors come into play with overheating. Too much dust build-up on & under the CPU fan blades. Dust builds up in-between the heatsink fins (Thus the CPU fan can not cool the CPU chip.)
The CPU fan may be running too slow. When the PC system shuts down it’s saving you from hurting the system. You did not list the model number of you're system. Check you're system & clean the mentioned parts. Use canned air & a dry clean small paint brush to help remove possible dust buildup blow the dust away with the canned air.
Mike
Jul 23, 2008 | Intel Motherboard
CPU fan stops, computer shuts down
You must have the CPU fan plugged into the CPU fan power connector or the system can not monitor the fans speed. Your PC will shut down & give you that message. (The fan must be connected to the correct power plug).
If when you did replace the CPU's fan & had to remove the heat sink, which is where the fan screws into & did not clean the old thermal grease off the CPU & heatsink & replace with new thermal grease than your CPU will still overheat. If you add thermal grease over top of old thermal grease your CPU will over heat.
This is all a balancing act. If any one is not correct your system will shut down. (This is better than killing the CPU).
To remove old thermal grease use a clean cloth damped with house hold alcohol & use the same on the bottom of the heatsink. Please allow plenty of time for the alcohol to dry.
Good Luck! Take your time.
Mike
Mar 30, 2008 | HP (P2074-63003) Motherboard
Shut down problem
if it gives you 60 secs warning , abort the shutdown by ---- shutdown /a---- command....and check for any servivice termination from administrative tools > services... check if all the automatic strted services are running
Jan 26, 2008 | Microsoft Windows Server Standard 2003 for...
HP Pavilion dv9000 Motherboard Logo
104 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
