Question about Ruud UBHC Air Conditioner
I have a rheem and the fan will not spin. Power is ok going to it.
  • 614 Answers
Bad capacitor or bad fan motor. Get service tech to give you a free estimate . Russ
Posted on Jul 18, 2009
No power/ no blower/in- or fan out side/only click on thermostate when set temperture
jump thermostat if ok replace thermostat if not check voltage to motor possible bad motor if thermos ok
May 26, 2014 | Rheem Heating & Cooling
Air handler blower fan doesn't blow. It does jerk a little every half-second or so.
When it tries to come on give it a spin with something safe (not your hand). If it takes off and runs replace the capacitor. It may just be missing the initial boost it needs to take off from a dead stop. That"s the capacitor's job.
Nov 27, 2013 | Rheem Ruud 51-24272-01 Blower Motor HVAC...
Rheem outside unit humming, fan not spinning
there is a dual cap in unit. kill the power and remove the silver cylinder. on top it has 3 places it can put wires. F, H, C. write the colors of wires and where they belong. take part up to granger and buy. 30 bucks most. replace. if same problem do the same with fan motor, around 60.
Jun 18, 2013 | Heating & Cooling
Rheem classic 80 fan motor on furnace hums will not turn on
Have you checked the capacitor? Try spinning the blower wheel by hand, if this gets the motor going you have a bad capacitor. If not, the motor will need to be replaced.
Nov 16, 2012 | Rheem Prestige 14 Series 2.0 ton 14 SEER...
Rheem RAKA 037 JAZ
When power is applied to the motor try spinning the fan blade with a small object such as a stick, if this gets the motor going than the capacitor is faulty and must be replaced. The capacitor is located in the outdoor unit.
Jun 21, 2012 | Heating & Cooling
Rheem condenser fan don't spin up under it'sown power.
If you have a multimeter that tests "uf" or "mfd" that is microfarads. That will test the capacitor. Turn off power to unit, touch top of cap with insulated screwdriver across terminals to discharge and remove fan and common. MARK WHICH WIRES GO WHERE. Or if no mfds on multimeter, amps×2650÷volts=mfd. Amp draw on fan wire off of cap times 2650 divided by the volts between common and fan on the cap. If cap is good it's likely the motor.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 12, 2017 | Heating & Cooling
Just replaced inside fan motor on 5 ton Rheem heat pump. Fan will not spin freely. What to do?
1) remove power from the unit
2) remove panels enough to see where the squirrel cage fan is binding
3) these units are normally adjustable by loosening the bracket which holds the fan motor and simply moving it one way or another just a bit. (which is why understanding which end of the fan is binding is a GREAT second step, right after step 1, remove power from the unit, that includes shutting the emergency heat coils breakers OFF.
Don't worry, you're close to the solution!
Nov 25, 2009 | Ruud UBHC Air Conditioner
Rheem water heater, will start but flame lasts 10 seconds
Is the vent fan working well and can you feel unobstructed air out the termination fitting outside?
Apr 04, 2009 | Water Heaters
Ruud UBHC Air Conditioner Logo
175 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
