Question about Mintek DVD-1600 DVD Player
I dont have cable in cable out and I lost the manual does something go in RF or SVideo connection
I threw it out
Posted on Jul 18, 2009
How do you connect AKAI model # PDP4290 to cable ?
You will need a cable box/set-top box with this TV. Contact your cable TV provider for this.
It does not have a direct RF connection, only AV connections.
For Cable TV support you can use
  • Composite video (single RCA connector)
  • SVideo (round 4 pin connector)
  • Component Connectors (3 RCA connecters red/green/blu)
Component will give you the highest quality signal (as long has the cable box supports this connection) You will also need to connect the Audio connectors (red/white RCA) from the cable box to the TV as well.
The full PDF manual for your TV can be found here: http://www.managemylife.com/mmh/lis_pdf/OWNM/L0502572.pdf
I hope this helps,
Magoo
Mar 11, 2011 | Televison & Video
I lost my color on my tv
If the cable was an SVideo, it's possible you might have a broken pin. Losing one of the 4 pins would still give you a picture but it would be in Black and White. Check both ends of the cable and if one is missing, get another SVideo cable.
May 26, 2009 | Samsung DynaFlat TX-P2764 27" TV
Proscan Svideo Input
Try Googling (proscan)(PS27115)(manual) without parens.
Jul 15, 2017 | Proscan PS27115 27" TV
I am trying to hook up an HD / DVR and my cable serice to a JVC AV2730 TV The TV ony has RF connector (none from HD/DVR box), S-video connector, and Video Component/Y Pb Pr hookups. Which ones do I use? My...
Well first off i am assuming that your jvc ONLY has rf connections?
if so, the most you can do is go get an adaptor from walmart that has inputs for either svideo or components and output for rf.
Sep 13, 2008 | JVC Televison & Video
My TV is fine...problem happen when I was moving today,not sure what its called but its the silver projection located on the back of the TV is which you connect the cable on the wall too...it broke...
Hook the cable up to the VCR or if you don't buy a RF converter from radio shack or electronics store which will have a coax connector on it with component and Svideo to send to the TV. Select the connection (Component or Svideo) in the TV menu. If you only have the coax connector on the back of the TV without any other connection, you will need to get that tuner board replaced.
Aug 18, 2008 | Televison & Video
During our move the connection for the cable was broken off and we're no longer able to connect the cable wire. Can a new adapter be installed enabling for attachment of the cable wire.
You can use your VCR to connect the cable into and then choose in the menu which output you want which is component or Svideo. If you don't have a VCR then go to radio shack or electronics store to get a RF converter which is for older TVs(really old) which didn't have a coaxial connector. Get the one that has component and Svideo on it. Then you connect the component to the TV component(or Svideo) input and select that input in the TV menu. Fixed!
Clock Setting problem Sony SLV-D300 DVD/VCR
I had the same problem at first as well. After an hour of frustration, I broke out the manual (imagine that! :) Come to find out, you cannot set the clock when in COMPONENT or SVIDEO mode. When I got the "For this setup, TV connection should be to DVD&VCR output" message, I can immediately switch the TV to RF mode (coax input mode) and voila!... the clock setup screen is available. I think it has something to do with the auto time sensing through the cable tv input. So, my advice - always be in RF mode (CH3 or CH4 depending on what you have the SLV-D300 set to) if you want to set the clock.
Note*** Yes, I agree it was idiocy on the part of the programmers in choice of wording for that error. A simple "Must be in RF mode to set clock" would have been much more helpful.
Mar 28, 2008 | Sony SLV-D300P DVD Player/VCR
Connevting to an LCD TV
This will vary by TV model, but some televisions route external signals to a separate video setting, often only reachable through the remote. Try looking for a "video" or "input" or "mode" setting on your remote. On my TV it's a "video" button that toggles from channels to Video1, Video2, Video3 and Svideo, then back to channels.
If that doesn't help you, let me know the exact make and model of your TV and I might be able to find something more specific.
-Dyllan
Jan 07, 2008 | Sony PlayStation (PS) Console
Sharp vc-a422
This is easy in a nutshell. from the cablebox into the VCR RF connection (ant in) then from the VCR RF into the TV RF in. The from the DVD composite video out and audio out into the VCR composite video in and audio in. This make the VCR the hub of your setup the VCR should be set to channel 3 and you can switch between the VCR and the DVD by using the VCR remote. Now for the cords: 1) Cable to VCR RF = Coaxial 2) Composite Video and audio out = RCA patch cable 3)Composite Video and audio in = RCA patch cable That is it. If your TV can support multiple inputs then use it as the hub. Cable Box to VCR RF (Coax cable) VCR to TV RF(coaxial cable) or VCR to TV Composite video, or TV Component Video (RCA Cable) DVD Player to Composite video, or TV Component Vido (RCA Cable), or Svideo (Svideo cable)
Sep 12, 2007 | Sharp VC-A420U VHS VCR
Connections
Hi If I'm understanding what you have written, the new DVD should hook up exactly the same way your old one did. You connect the red and white cable from the "Audio out" connectors on your new DVD to the "Audio In" connectors on the RF modulator, then connect the Svideo out on the DVD to the Svideo connector on the RF modulator. Then put your TV on channel 3 or 4 depending on what the switch on the modulator is set to, and all should work fine. I would advise you hook your old one back up, then if it works, simply unplug the cables from you old DVD and plug them into the proper jacks on the new one. This eliminates bad cables. If you then get sound, but no picture, the DVD may be set to progressive scan (check manual for procedure take it out of that mode),If you get nothing, then I suspect there is a problem with the new DVD player. The TV/VIDEO switch they mention, would be a switch on the TV or TV remote if you had a newer TV with RCA inputs.....You don't, so disregard that, it does not apply to your TV. You would not need the RF modulator if your TV had that switch. Good Luck!...These things can be a pain, I hope this helps!
Nov 28, 2006 | Daewoo DVG-9200N DVD Player
Mintek DVD-1600 DVD Player Logo
109 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
