Question about GE Security Simon 3 Wireless Home Security System
My alarm keep repeating the phrase "module ok" about every 5-7 minutes I thing it is the backup battery. I have not been able to make it stop. How do I get it replaced.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
If you can, disconnect the battery and see if the messages stop. You can get a replacement at Batteries Plus or Radio Shack,etc.
Posted on Jul 23, 2009
How do I unhide alarms 2 and 3?
Set multiple alarms. If any alarm is active,(picture of alarm hear) appears in time display A. Press MODE repeatedly until ALARM appears, followed by ALM1. Press STOP/RESET to select Alarm to set. B. Press SET/RECALL to set alarm. HOURS digits will flash. Press +/- to change HOURS. C. Press NEXT and +/- to set MINUTES, AM or PM (if primary time display is in 12-hour format), DAILY, WKDAYS, WKENDS, or day of the week (weekly alarm). D. Press DONE to exit. E. Press +/- to set different Alarm. Set as above. F. In Alarm mode, press START/SPLIT to turn Alarm ON or OFF. TIP: Alarms apply to selected Time Zone of watch display. Backup Alarm sounds after 5 minutes if no button is pressed. Turning off any Alarm or backup will not affect other alarms. http://assets.timex.com/user_guides/W191_M131/W191_M131_NA_EN.pdf
Dec 01, 2015 | Timex Sports Ironman Triathlon 100-Lap...
Aplique alarm 6 14 keeps coming on randomly
The only alarm system I've had is my 12ga with deer slugs.
It shouldn't be too hard to either turn it off, or find the problem power supply. I am thinking the power to the house may have blinked off and on at some point, and the logic of the alarm is freaking out as a result.
Is there a backup battery for the alarm system? If not you could try turning off a circuit breaker at a time until you diagnose which one is powering the alarm system. If you find one that turns the alarm pad off. Leave it off for a few minutes and turn the breaker back on to see if it will reset itself. If the alarm has a battery backup try to remove it and again turn off the circuit breaker. Also search your book for resetting the alarm system.
Dec 01, 2011 | Cars & Trucks
Our hard wire smoke detector model i12060 just beeped really lound a few times and stopped, it glows green and flashes red every few minutes?
Change the 9V backup battery,with a new one.Push and hold the reset button for a minute or two for the alarm to to go off like about 30-40 sec. for the smoke detector to dectected the 9V backup battery power sourced.The green power LED light indicator will stop flashing also the beeping sounds too.
Jul 12, 2011 | Kidde 120-Volt Front Load Battery Smoke...
I accidentally locked myself out of my Smarthhome Securelinc Alarm Installer Code Model OH-41073AT. I would like to reset the unit to my installer code or create a new one. Can you assist?
The first thing to try would be to disconnect the mains supply and remove the internal battery for a minimum of 5 minutes and then reconnect it.
If this doesn't reset the system then remove the mains supply and battery again for another 5 minutes.
After 5 minutes reconnect the battery.
Then with the help of a friend try holding the # & * keys while they turn the mains supply back on.
These are generic resets for most house alarms but I'll keep looking if there's a specific one for your system so if neither of these work just let me know.
If I find anything else in the mean time I'll add to this post.
Jul 06, 2011 | Visonic INC Smarthome SecureLinc Wireless...
My Van Was Running OK The nekt day I started the engine, & runs for 5 sec, & stop, keep douing the same thing
Your alarm went off. This is common if it was your crank or cam it would start shut off but give you more than five seconds, Try this roll down a window disconnect the battery and put both terminal together, this will try the BCM(body control module) hod terminal together for 30 seconds reattach the battery put the key in the ignition for 10 seconds in the ACC position then start it. see if that works
May 19, 2011 | 1997 Chrysler Town & Country
My first alert smoke detector went off at midnight last night. It is doing the three beeps, pausing and then another three beeps. This happened for about 3 minutes, stopped and then started again...
Change brand new battery,every three months.Take some rubbing achahol clean the test button metal contact inside the detector.Well works correctly after these steps.
Dec 15, 2009 | First Alert SA302 Dual System Smoke...
Our system keeps repeating module ok how can
replace the 6VDC 1.2AH battery. The module runs directly off the battery and it is not keeping a charge.
Alarm Professor.net
Oct 08, 2009 | GE Security Simon 3 Wireless Home Security...
Power outage last night - alarm sounded. Turned off computer - pressed the button to silence alarm. Five hours later, battery sounded a different alarm every 20 minutes that could not be stopped. Gr-r-r-r!...
hi..OK 1st step open the unit and find the memory from the board remove the memory then make clean the all pin connectors using a paper eraser.if u have video card remove too then same make a clean..good luck and have a nice day...Thanks
Jun 14, 2009 | Tripp Lite Lite OmniSmart 700 PNP UPS...
The alarm says module ok every few seconds
Reason: The reason why the sys is saying module ok is becasue of the panel battery. This is a common problem with simon 3 and thats why i would not suggest this sys to anyone. The module is the cell unit thats send the signal to the central station wirelessly and it gets it power from the batteries.
Fixes. The only way to fix this issue is by replacing the panel batteries.
Jan 13, 2009 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
537 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
