I was given this machine and I cannot fill the bobbins on it. It is 1973 model
SOURCE: bobbin filling
The handwheel may have a pull out/push in action to disengage/engage the clutch, or it may automatically disengage when the bobbin winder is moved to the right for winding........hold a short tail of thread to get it started and you should be away.
Move the winder to the left for sewing, or push handwheel in, according to the mechanism.
SOURCE: bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
SOURCE: Filling the bobbin with my Juki DDL-5550-6
It's actually designed that way on purpose so you can wind a bobbin while sewing. If you lift the presser foot, at least it'll make less noise in the process.
SOURCE: singer futura model 900 sewing machine
Recently had same problem. Underneath the bobbin area on the bottom of the machine is a small white plastic piece that resembles a fan. Singer calls this the bobbin cam actuator. It is usually cracked along the sleeve that fits over the metal pin, bar? This is the mechanism that lifts the bobbin when it is wound. When its broken it can't lift the bobbin to be wound properly.
