Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
I have a Honeywell CT2800 Thermostat and a message FR Return came on
It's just running your "return home" program, so it says "return". the FR above it is just meaning "Friday". They line up in a way that makes it look like the two words are together but they aren't, the week line is just right above the program line.
Posted on Dec 12, 2009
What is fr return?
Posted on Aug 01, 2009
  • mikecox Aug 01, 2009
    what is fr return
How do I set the temporary or permanent override feature on the Honeywell RTH2310B model thermostat?
To set the temporary override, press arrows up or down to desired temp. This will keep temperature
at temporary setting for 2 hours then return to programming. To permanent override press MODE button until schedule period number disappears (number inside little house on stat). Then adjust temp with arrows. Press the MODE button again to cancel override and return to programmable.
Jan 25, 2011 | Honeywell Programmable Thermostat Heater
Bae lo This is the message my electric Honeywell programable thermostat is flashing. It's still working. What's that mean? Thanks.
Try with this site:
Honeywell thermostat website: http://yourhome.honeywell.com/home/Applications/SmartSearchResults.aspx?searchkey=thermostatfor heating
Dec 12, 2010 | Heating & Cooling
Need to know how to calibrate my honeywell RTH221
This thermostat is not field servicable,you cannot calibrate this thermostat.May want to consider moving it closer to return air of equipment, for more accurate sensing of building temperature. Why do you feel that it needs calibrated? Suggest setting another thermometer on top to verify its accuacy.
Nov 24, 2010 | Honeywell Heating & Cooling
Thermostat is reading FR Return what does this mean? It is a honeywell CT 3200.
My new blanket works great. Then I changed my sheets and would get the F2 problem. Very consistent after 5 tries with F2 blinking by unplugging at wall outlet and comes on with F2 blinking. Let it rest a night and still the same.
Then I unplug it at the blanket. Hmm, notice a pin was lower than the others. PUSH BACK IN FIRM and tried again. Perfect.
Apr 03, 2010 | Honeywell CT3200 5-2 Day Electronic...
What does FR Return mean when thermostat says this?
it means that it is friday and your "return home" program is running. there isn't actually a "FR Return" alert, it just lines up that way because the day of the week line sits directly above the program line.
Dec 11, 2009 | Honeywell Electronic Programmable...
How do i stop the filter message blinking?
go to www.honeywell.com, there they have a search engine. Put in your model number of the thermostat and look for the users manual.
Dec 27, 2007 | Honeywell Programmable Thermostat Heater
Thermostat
I have a Honeywell Programmable Thermostat, T8011R. The users guide for the T8000 series can be found at:
http://www.honeywell.com.au/business/acs/acp/ecc/ec/residential/identify.html
To keep your temperature at a single setting, just enter the temperature at every period, i.e. WAKE, LEAVE, RETURN AND SLEEP for both the Monday through Friday time frame and the same for the weekend. I do this at 55 degrees when I'm going to be out of town.
To 'Guest' , enter your 68 degrees at WAKE, LEAVE and RETURN, then enter 66 degrees at SLEEP. Do this for the Monday through Friday time frame and again for the Saturday - Sunday time frame.
Dec 19, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
1,750 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
