Question about Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux Advantage Series canister vacuum
How do I replace the air filter. I can't figure out how to open the rear of the canister?
  • Anonymous Mar 21, 2014
    canister vacuum
    canister vacuum
  • 75 Answers
There is an area on the back of the tank where you will see lines, put your thumb there and pull the top half of the tank towards yourself. That should open the machine so you can replace your after filter.
Posted on Dec 29, 2007
I need to find out how to open the cover to change the motor filter on my Electrolux Epic Series 6500 sr canister vacuum.
There is not a replaceable motor filter inside the body of the vacuum. There is an exhaust filter under the cover on top which can be removed by pushing a little tab at the rear of the cover.
Nov 15, 2017 | Electrolux Vacuums
Ultraactive vaccum filter keeps popping off
There are two possible causes for this issue. The most likely is that your exhaust filter is blocked and so the air literally cant get out. You need to replace the exhaust Hepa Filter every six months anyway so get a new one and see if that fixes the problem. If it still is popping off after this it means the tiny lugs on the filter cover are damaged so you will need to get a new one of those.
Jul 11, 2013 | Electrolux UltraActive Turbo Bagless...
Electrolux Advantage Series Vaccum is making noise when vaccum, what may be causing that?
here is the manual ,if you slid the bumper strip off the one thats marked number 6 the cylinder should come apart, the bumper strip holds it all together..
Dec 06, 2012 | Electrolux Lux 7000 Bagged Canister Vacuum
How to use the after filters for the electrolux canister vacuum
At the back of the vac on top you will have a removable grille. Release the thumb tab to lift the grill.Older models had this tab at the back of the grille. The filters will sit underneath. They should clip into the round exhaust opening. Then replace the grille. Change filters every 6 bags. More often if you have pets or allergies.
Sep 12, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux #1521 Canister Vacuum won't stay closed
hi from uk your problem with the canister cover/door coming off whilst vaccing ? you have renewed bag ? ok but there is a filter/gauze also inside the canister where bag is fitted if you check inside you should see the filter at opposite end from where bag is secured it is usually fitted behind a slotted pull out plastic gate ? this filter/gauze is to allow air out of canister when vaccing and the filter traps any dust that may accumulate inside the canister case so the dust does not get blown out to atmosphere/rooms SO if this filter is clogged it will not allow vacced air to escape out of canister so result is build up of pressure within cylinder and eventually cover flips open ! so for now you can remove filter/gauze and wash then dry refit this will allow air to escape from canister but still retain dust particles from escaping as it is designed for however may i suggest you replace filter when convenient ? all above is on assuming that the latch on cover is working ok and not now damaged ? hope this helps best wishes
Mar 01, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Back filter and its door blows off as soon as I turn it on.
thats good has good suction i guess there should be a cover on that back filter if you can't find you can tape it down leave air coming out
Jan 31, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Jul 06, 2008 | Electrolux UltraLux 2000 Bagged Canister...
How do we open this vacuum?
Some of these, the strip on each side, in the middle, slide off, then the 2 halfs will separate. They only slide in one direction and some are hard to get off.
Mar 09, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux Lux 7000 Bagged Canister Vacuum Logo
572 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
