Lexmark S415 - multifunction  fax / copier / printer / scanner   color Logo
Amber Jones Posted on Jun 23, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer is in "error state" will not print.
I replace the ink, and now printer will not print, it is not connecting to the computer. It has a communication error.
Marvin
Level 3:
Top Expert:
  • Lexmark Master 85,242 Answers
  • Posted on Jun 23, 2016
Marvin
Lexmark Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29057026
Points
266281
Did you use a new factory cartridge? If not the cartridge may be shorted.
Testimonial: "No I used a different company, but it worked the last time."
  • Marvin
    Marvin Jun 23, 2016
    I have run into this before, put the old cartridge back in and see if the problem clears, if it does the remanufactured cart is defective.
2answers
Problem with printing, no ink on paper
The print heads are clogged or you are out of ink. Try the steps in the link (Epson support page).
Epson WorkForce WF 2530 All in One Printer
My envy 4500 series is in error state and wont print,what can I do.
The Brother Printer In Error State Windows 10 is an error normally displayed when the printer is jammed, low in paper or ink, the top is open, or the printer is not connected properly etc. Here some relevant answers to fix this error. the printer is in an error state, unable to print documents or unable to connect to the printer? Here every possible solution to fix Printer in Error State or Offline on Windows 10. Several windows users report After New windows 10 fall creators update or Install the latest updates attached printers stopped working or getting Printer in Error State problem.
4 Easy steps that resolve Brother Printer In Error State Windows 10 Easily.
1. Check the Printer Joint: Check the power cables attached to the wall outlets and also the USB wires connected to the PC.
2. Restart the Printer and Computer: Turn OFF and ON the Brother Printer.
3. Check the ink levels: In case the Brother Printer ink is very low or coming to an end then kindly replace the toner.
4. Check Paper jams: Look out for stuck papers inside the Brother Printer.
If you want a full blog about Brother Printer In Error State Windows 10 check this blog which is mentioned. Just follow the steps which are mention on the blog to fix the Brother Printer In Error State Windows 10. We give online help for Any problem in printers our Call us on TOLL-FREE NUMBER which is mentioned in our BLOG.
2answers
Printer in error state
The Brother Printer In Error State Windows 10 is an error usually displayed when the printer is jammed, low in paper or ink, the cover is open, or the printer is not connected properly, etc. Here some applicable solutions to fix this error. Check all think that cause this Brother Printer In Error State Windows 10 Turn off the printer and check for a paper jam. Check if the printer is low on ink. If you are using a WiFi printer, turn on the WiFi of the printer and the modem router.
Solutions to Resolve Brother Printer In Error State Windows 10:-
1- Turn the Offline or Pause Printing Status of Brother Printer.
2- Restart Print Spooler to Resolve Brother Printer In Error State in windows 10.
3- Enable Automatic Updation Of Brother Printer Drivers.
4- Allow Plug and Play Detection to Resolve Printer in Error State.
5- Uninstall the Brother Printer and then Reinstall It Back to Your Computer or laptop.
If the problem continuous check this blog for a full solution with expert advice-Brother Printer In Error State Windows 10
2answers
Epson printer in error state
3 Method to Fix Epson Printer Error State:-
Method 1: Check the connection and restart your Epson printer.
Method 2: Update Printer Driver.
Method 3: Contact Printer Support.
Epson Printer Error State is an error usually displayed when the printer is jammed, low in paper or ink, the cover is open, or the printer is not connected properly, etc.
You can check whether the connection between your printer and computer functions normally. The Epson printer in error state can also result from the faulty or incompatible printer driver. If you have tried the methods above and the error continues, you may need to contact the Printer support team to resolve Epson Printer Error State.
We have here provided some simple and easy steps through which it would be helpful for all users to fix the printer error. Therefore, for an instant solution, scroll down and follow the blog to fix Epson Printer Error State.
5answers
Printer wont print. Keeps saying printer in error state. Control panel says printer ready
Brother Printer in Error State Windows 10 difficulty is an error normally presented when the printer is jammed, low in paper or ink, the cover is open, or the printer is not connected properly, etc. Here some relevant solutions to fix this error. The Brother Printer in Error State Windows 10, unable to print documents or incapable to connect to the printer? Here every possible solution to fix Brother Printer in Error State Windows 10. Several windows users report After Recent windows 10 fall creators update or Install the latest updates connected printers stopped working or getting Printer in Error State in windows 10 problem.
Right steps to Fix Brother Printer In Error State Windows 10:-
1. Check Network Connectivity.
2. Install Proper Printer Software.
3. Connect the printer that requires troubleshooting.
4. Full blog with a guide on how to fix Brother Printer in Error State Windows 10
The Brother Printer In Error State Windows 10 is a very harmful error this error is very annoying. If you want a full solution to this error check this blog and follow the steps given in the blog. We provide online support to any problem with Brother printer Errors.
2answers
I have been using an epson stylus color 880 for years. One day it would not print. Replaced the cartridges and still will not print. It goes through the printing procedures but nothing shows up on...
The print head nozzles may be clogged. From the Utility section found in the EPSON printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Perform up to 3 cycles if necessary. If the nozzle check is not printing completely, and if the head cleanings do not help the nozzle check pattern to print completely, try replacing the ink cartridge. Any ink cartridge installed into the printer must have a blue label on top of it. If the blue label has been removed from the ink cartridge, do not install the cartridge. Using an ink cartridge, which does not have the blue label on it, may damage the printer. Caution: If you have already installed a cartridge which is missing the blue label, or if a previously installed ink cartridge was missing its blue label at the time it was installed, and now head cleanings do not help the nozzle check pattern to print completely, your printer may require service and you should contact the EPSON Connection for further assistance.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
When the printer is turned on it states: ink system failure. Unable to print. Refer to printer documentation. Error Oxc18a0001.
possible causes of this:
  • loose or improperly installed ink cartridge
  • damaged cartridge
  • dirty print head
Solutions:
  • check cartridge connection, try to remove and reconnect
  • replace damaged cartridge
  • clean printhead using the printhead cleaning utility software of your printer
I received an error message that ink cartridges needed replacing. I replaced the ones stated and checked the ink levels on the computer. The report is that the ones replaced are at 100% and the others have...
If you are using refilled (worst cartridges) or third party cartridges then that is most likely the problem.
If you are using factory new HP cartridges, then you need to contact HP to get the cartridges replaced.
Don
2helpful
3answers
HP Business Inkjet 1000 error detecting new cartridge
Disconnect the communication cable (USB?).
Turn off the printer, wait one minute then turn it back on,
Then press the left button on the panel, the transparent one to the left of power button. It will print a status page. Check the dates and information under each color that is failing.
The ink cartridges MAY be outdated. Printing the test and information page without the computer connected fools the machine since it can't get your computer date.
If the cartridges are outdated, then change your computer year back to 2005 or so, reconnect the printer cable and send something to print, once the printer prints it out, reset your computer to today's year.
You will need to do this procedure whenever you turns off the printer. (Disconnect cable, change computer year, print, reset computer date).
Hope this works.
Wagner
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
