Question about Toshiba Satellite A100-S8111TD Notebook
Toshiba Satillite A100 not powering up
My Toshiba Satillite A100 has all of a sudden stopped powering up. There is power going to it because the power button flashes but it won't start up. I first noticed this when i turned it on, and it powered up but the keyboard wouldn't work, so i powered down and started it again, not it won't start at all, the light just flashes........
    Problem Solver:
  • 8 Answers
Re: Toshiba Satillite A100 not powering up
again $ again try 3 or 4 time to powerin on with ac mode,if not powering on then try it in backup mode with support battery if u dont have battery backup then get a battrey from any other laptop but it must be same model if powering on then change your adapter and try again if then also not warking go to nearer vender or service center.
by by.
Posted on Nov 19, 2007
0 characters
3 Points
Z,/,?,and all four directional keys stopped working on my toshiba satillite c655-5128
The keyboard will more than likely need to be replaced, there are no user servicable parts. Go to type make and model of laptop, refine search to keyboard.
Aug 31, 2012 | Toshiba Satellite C655-S5140 Notebook
How do i clear cmos baterry on my toshiba satillite A205?
Start your computer, and enter BIOS SETUP.
Select "Load BIOS Defaults".
Save & Exit from BIOS SETUP.
Aug 29, 2010 | Toshiba Satellite A100-S8111TD Notebook
Problem: A100 flashing Amber light but won't turn
Check your charger. It seems to indicate low batery and the charger may not work or the power socket has a faulty connection. Check for phisical damage in the power socket of you laptop.
Try to twist it or even push it in a bit while trying to switch on. Try also to remove the baterry and use the charger power supply only.
If nothing happens its very likely to be the charger.
Jul 23, 2010 | Toshiba Satellite A100-S8111TD Notebook
Suddenly CD DVD do not shows in My Computer. When any CD / DVD in the tray it power blink and then stop
the only thing you have to do is :
  1. On the Windows Start menu, click Run.
  2. In the Open box, type Regedit and click OK.
  3. Select the following key in the Windows registry:
  4. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\
  5. On the Edit menu, click Delete:
    Value Name: LowerFilters
    Value Name: UpperFilters
  6. On the Registry menu, click Exit.
  7. Reboot your computer.
Mar 11, 2010 | Toshiba Satellite A100-S8111TD Notebook
I have a Toshiba A100, the USB ports are not working all of a sudden.
Hi there. All you should need to do, is download and install your motherboard/chipset drivers for your system.
You can download them from the Toshiba website here:
You will need your model no. As there are 7 different A100 models. It will look something like this: A100-ST1041.
If you need me to clarify anything, just reply to this post. If it works, please rate.
Apr 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
My toshiba satellite a100 laptop is no charging . No charging indicator display.Charger is ok. I go laptop service center.He said me that is charging and power ic is burn and short. but ic is...
If its still under warranty then give it for repairs. Does this laptop have a DC input slot, if so use that since it will bypass the power IC and directly feed the requisite power for operation & charge the batteries too........sodeep.
PS: Laptop replacement of any IC is very intricate and should be done by the manufacturer through their authorised service center. Don't worry there are authorised Service Centers in India, but where do you recide? Then I might be able to send the nearest authorised Service Center address.
Mar 14, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba a100 freezes
check the power adaptor
give a check to your battery also
instead of doing it urself i suggest to show it to a service person
Nov 23, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satillite A100 "TBX Error"
This needs BIOS Reprogramming. Go to the nearest service station for the Chip to be reprogrammed.
Sep 14, 2007 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
236 people viewed this question
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
