Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
The fridge won't turn on. can't move the temp control up from 0. I turned it off (moved the setting to 0) 8 days later I can't turn it on The power is OK Lights working
Press and hold up button for 30 sec
Posted on Jul 18, 2009
After being moved, why does front temp panel no longer adjust?
what is the model number? did you move the plug connector at the top hinge under the hinge cover? Check to make sure plug is tight
APPLIANCE 911
Jan 04, 2016 | LG Refrigerators
Fridge temperature too hot won't go down with temperature controls
This looks like there is a problem with thermstat in the fridge. We had a fridge that would not cool and we found it to be the thermastat problem. You have to replace the thermstat on the fridge. Not 100% sure but a high possibility.
Mar 23, 2014 | Frigidaire Refrigerators
Why is Fridge not cooling well?
The part number you need is going to be WR09X10050. This is for the damper assembly, but while you are at it change out part number WR55X10150. this is the part that controls the damper and more than likely if one fails the other will be soon to follow
Jun 05, 2012 | Hotpoint Refrigerators
Electronic controls at 0
Did it quit cooling also? Where is the humming coming from?
Nov 24, 2011 | Amana ARB2217CSR Bottom Freezer...
Items in refrigerator are freezing
The temp control in the fridge actually moves the flap the opens and closes in the venting between fridge and freezer. This vent can get stuck or frozen in one direction. A good thawing out which is recommend once a year for any unit is not a bad idea.
Thawing of this vent and flap are a good idea. Once it is thawed out or unstuck, then move the temp control around to see if the flap will move. Then you can turn it down so freezer is colder and fridge is not freezing up.
Jan 25, 2011 | Samsung Refrigerators
The freezer temp is fine but the fridg temp is 50 degrees. It will not get colder than that. I have left it off for 24 hours to defrost and turned it back on and this did not solve the problem.
try moving the temp around,then if you tryed that already then defrost your frige turn off completly for one day if that dont fix it check if switch is working,last thing is the change the compressor
Sep 10, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Turns off won't turn back on unless you move thermostat
Sounds like a defective cold control ( off/on thermostat).
They will tend to stick in the off position. Your moving the knod unsticks it.
May 24, 2009 | Whirlpool ES5FHAXS Side by Side...
We just moved into a home with a 3 year old GE side by side refrigerator (model# GSS 25LGMB BB, serial# VA 412740). It works but it's not as cold in the fridge section as it should be and we have it on the...
Ok, this is a temperature control board malfunction. this board control the temp throughout the box and , if it is unstable and unable to regulate the temp, it will produce erratic fluctuations within the box itself. simply replacing this board will fix this issue.
CLICK TO PURCHASE THE TEMP BOARD
Please rate and god bless:)
May 11, 2009 | Refrigerators
Whirlpool sidexside m-gd25dq does not cool properly
Sounds like bad cold control. Replace it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 15, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
236 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
