Why wont a washer spin out when it doesnt have a belt
I have trouble with my washing machine it has suddenly stopped rinsing/spininng the belt is ok any other suggestions. its a hoover performer
Posted on Aug 19, 2009
    President:
  • 1,136 Answers
Hi, The coupler replaces the belt and it could have broke. Other options are, the lid switch is bad or the spin basket drive assembly or the transmission. If the coupler is broke, the washer will not agitate either. If the lid switch is bad, the motor will not run either while in spin cycle. If the spin basket drive or transmission are bad, it might spin a little but not strong enough to get the water out of the clothes.
Does nay of these sound like they are what is going on with your washer?
Please let me know if this has helped you at all or if I can assist you further.
Thanks
Vic
Posted on Jul 17, 2009
  • Victor
    Victor Jul 17, 2009
    Thanks
    Vic
3 Suggested Answers
  • 1314 Answers
SOURCE: washer wont do spin cycle
for safety most washer have a lid switch that the lid engages if that switch is bad wont spin lid must be closed for spin also
Posted on Dec 30, 2007
dniro592006
  • 121 Answers
SOURCE: wont spin how do i open to see the belts
is it a direct drive moter?
Posted on Jun 02, 2009
Washing machine has smell (burning) and doesnt spin or drain tub.
Sounds like the belt may need to be changed. it eh pulley are spinning but the belt is not, nothing will spin and the friction of the pulley against the belt will cause a burning rubber smell
Nov 27, 2013 | Washing Machines
Washer wont spin ...motor runs but drum doesnt
If this is a Duet front loader, you need to check to see if the drive belt may have broken, or slipped off the drive pulley behind the wash tub.
To access and replace/reinstall the belt, the following link explains:
http://www.fixya.com/support/r3609900-drive_belt_installation_whirlpool_front
If you have any questions, or if the model washer you have is different, please post back and let me know. I hope this helps you.
Jun 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
It wont spin and it looks like the drum isnt moving, is it belt driven?
It will never spin if the drum doesnt turn. Check the drain pump for any obstruction and look for any blockages in the pipes.
Jun 05, 2010 | Zanussi FC1200W Front Load Washer
Will drain but wont spin
Try these
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
pls rate my suggestion......
Jul 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washes but doesnt drain or spin
Unplug Washer
Shut of Water hoses to Washer and Disconnect from Washer.
Turn washer around and remove back cover.
Look inside fro the Belt it should either be Loose, or Broken. Just Replace.
Hope that helped
Please Rate Me
George
Apr 29, 2009 | Washing Machines
I OVERLOADED THE WASHER AND NOW IT WILL NOT DRAIN OR SPIN
your washer doesnt have a belt, it is a direct drive with a coupling on the motor, so that is not likely your problem.
i would look to see if the lid switch is broken, when the switch wont work it wont spin or drain. if the coupling is broken it wont agitate or spin, but will drain the water.
just look under the top and see if the switch is just hanging loose. it has 2 screws holding it to the cabinet and a wiring harness that goes to the control panel.
Jan 08, 2009 | Roper RAS8445KQ Top Load Washer
Frigidaire GLET1142CS0 washer wont spin
I Changed the TUB belt and now it spins.
Jun 10, 2008 | Washing Machines
Washer wont spin
Is the lock door light on if not change the wax motor & the main control board (board is approx $169.00+).That is the problem unless the belt slipped off .Common neptune issue you have will most likely repeat itself so,you decide from there.
May 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer wont do spin cycle
Dec 30, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
115 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
