Question about Cell Phones
I cant unlock sagem my w-8 sent to me from italy
The numbers are 357356000129028252362153/myw-8
S agem my w8 3 sin not present why give me the right code to unlock it's not Vodafone into but the serial is 356794001755378 made in eu
Hi are you looking for sim network unlock code to unlock your sagem Myw-8 mobile from network provider .Then you can purchase code from online providers like ProUnlocking.com for reliable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone then freely use it with any GSM sim ...
Dec 15, 2014 | Cell Phones
Sagem my w8 3 sin not present why give me the right code to unlock
Hi are you looking for sim network unlock code to unlock your sagem Myw-8 mobile from network provider .Then you can purchase code from online providers like SuperUnlockCodes.com for reliable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone then freely use it with any GSM sim ...
How to download free download software to unlock sagem myw-8 mobile phone?
It is not advisable to use software to unlock the mobile, because it makes the thing complicated, it is better to use codes than software because it works fastly and accurately, the site name is http://www.mobile-unlocker.com/
Jan 18, 2010 | Cell Phones
Sagem my511x mobile phone locked
You have to contact your current service provider. And tell them you want to unlock your phone they wil ask for the imei# Give them the imei# and they wil give you an unlock code.
Sometimes you have to send a request from there site but it depends on te service provider. Just call them and you'll know ;)
Feb 21, 2009 | Sagem my201X Cellular Phone
To connect Sagem myW-7 to the internet without myService provider
Hi!
Connecting to the internet through your Sagem phone can only be done through your service provider because it acts as your gateway through the internet. Please check with your service provider if it supports internet connectivity.
Cheers!
Dec 23, 2008 | Sagem My501X Cellular Phone
My sagem myW-8
i want to software to decode the above-mentioned phone Sagem myW-8
Aug 13, 2008 | Sagem my700X Cellular Phone
Unlock sagem my w-8
Hello! I have similar situation with mobile. As a gift I resieved Sagem my W-8 from Italy. I insert ukrainian card n it write "sim is noy allowed".What to do?If u can please help me!
MY MOBILE IMEI NO:356794001608577.
PLEASE SEND ME THE UNLOCK CODE ON MY E-mail adress:Svit_sv79@mail.ru.
thank U before
Svitlana from Ukraine
May 13, 2008 | Cell Phones
SAGEM my220X unlock
can some one tell me about any free software 4 unlocking sagem my511x
Jan 28, 2008 | Sagem my201X Cellular Phone
UNLOCK SAGEM MY W-8
imei unlock 332052-35-125357-0 3927257920 332052-35-129377-0 3362230830332016-35-146513-0 1558898480 332052-35-126828-0 4011806542332052-35-126963-0 0079539739 332049-35-321828-0 1503515261332052-35-126971-0 3852379919 332049-35-236282-0 1395096725332052-35-127534-0 0810548649 332049-35-176328-0 0947921989332052-35-128668-0 3830409997 332052-35-176099-0 0948020856332026-35-148914-0 0270060834 332052-35-174998-0 0445933997 Tout d'abord il faut rentrer dans le menu hotline3 du portable. - Pour ce faire, tapez *#06# afin de connaitre l'imei. - Enlevez les six premiers chiffres et le dernier. Il vous en reste donc huit qui doivent commencer par 35 ou 82. Procédez de préférence sur un tél sans carte sim. - Tapez * + les huits chiffres puis OK. Le menu hotline2 est activé. - Ensuite entrez dans le menu normal du tél puis tapez *. allez dans RAM, tapez l'adresse 112, validez, appuyez sur C, tapez 2 en nombre d'octets et validez. Apparait alors à l'écran : adr:112 puis 8967. Appuyez sur modifier ou C, tapez 7698 et validez. Voilà, le menu hotline3 est actif. Ce menu permet de lire et d'écrire dans tous les champs EEPROM (menu normal puis * puis 3, prom) sans câble. - Avant tout, allez dans le menu PROM, lecture/écriture, tapez 231 en champ et validez. Il y a 0 ou 00. Ce champ est le compteur de mauvais codes simlock tapés sur le gsm. Donc si vous en avez rentré le compteur doit être supérieur à 0! Mettez ce champ à 9 ou F s'il n'y a qu'un seul chiffre ou à 99 si y a deux chiffres. Ainsi le compteur est bloqué mais le temporisateur est désactivé, vous pouvez donc taper autant de simlock faux sans aucune incidence. - Maintenant allez dans PROM, tapez 0 en champ. Vous obtenez une série de lettres et chiffres que vous inscrivez soigneusement sur une feuille. Vous faites "annuler" et encore lecture/écriture mais cette fois çi avec le champ 251 et vous notez son contenu. Sortez du menu PROM pour allez dans RAM mais cette fois çi à l'adresse 219 avec 6 octets. Notez aussi le contenu. - Lancez le soft SAGEMSLCK, quand il vous demende de taper "I UNDERSTAND" vous le faites en majuscules obligatoirement. Il vous demande ensuite le choix "par câble" ou "manuel". Tapez "m" (en minuscules obligatoirement) manuel. Le soft demande ensuite de taper les contenus des trois champs eeprom et ram précedents et lorsque vous validez il vous donne le code simlock à dix chiffres.... Et votre phone est débloqué !!!Ca ne marche pas sur certains modeles. C'est peut etre dû a la version du soft qui est peut etre trop récente.Tenez moi au courant. Pour les Sagem 9500 et autres ??? des ptites indications au cas où les manips. seraient pas clairs :"il est difficile de deviner où il faut rentrer le code de deblocage une fois obtenu. Et c'est pas indiqué chez toi qu'il faut faire * apres Menu, etensuite qu'il faut rentrer dans la rubrique Sim lock."
Oct 24, 2007 | Lands Phones
Cell Phones Logo
55 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
