Water leaked back out of dirty water tank on to carpet
Hello, this is Ava with Think Crucial.
First, make sure that the caps are on securely and the red rubber auto-load gaskets are in place. If the red rubber auto-load gasket is missing, check to see if it's stuck in the reservoir. Next, check the tanks for cracks or damage. If there is damage then you may need to replace it. If your gaskets are correctly assembled and your tanks don't seem to be damaged, at this point it might be best to take your carpet cleaner to a technician. You can call Bissell at 1-800-237-7691 for authorize service center near your area.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=bissell
Ava B.
Think Crucial Customer Care
SOURCE: I have a Bissell proheat 2x and it leaks water
check to see if the seal came off the tank and stuck in the dock
SOURCE: not picking up water on a bissel proheat turbo 2x
If unit is not picking up solution it is most likely the small red plastic filter that is just above the small float door in the top piece just left of the tool switch.. pop it out clean muck out of it and it will work like new again.. have fun!!
SOURCE: Bissell proheat 2x carpet cleaner
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Here is a tip that will give you all the information you need to fix your Bissell
Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
SOURCE: My bissell Proheat 2X Carpet cleaner will not
Normal
0
font-size:10.0pt;
heatman101
SOURCE: bissell proheat 2x carpet cleaner 9200 How do i
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
teyet
