Question about Onkyo TX-DS474 Receiver
Re: ONKYO with New LCD HI Def Television
HI i am trying to hook up my new LCD televison with a samsung Hd DVD and my Onkyo receiver
Hi Lucylu
I don't have a solution to your problem -- but I do have the receiver and want to hook up my Plasma TV through the ONKYO TX-DS474 receiver. Its a great receiver but am not sure it will "do the job" being so old in the tooth.
Hope you found a solution!!
Posted on Apr 15, 2008
On the Onkyo receiver, I have a uverse box hooked to an hdmi input, and a Samsung un55c8000 hooked to the hdmi out. Even though the uverse box is set to output 1081i, the Onkyo receiver tells the...
Hello, please press and hold the display button on the remote for 3 seconds to confirm the incoming resolution from the cable box. Thank you, Onkyo USA
Jun 04, 2017 | Onkyo TXNR708 72 Channels Receiver
Onkyo tx-sr604 help
You said you tried hooking the HDMI up directly from the TV to each component, and that worked. How is it usually hooked up - through some kind of switch? I'm not completely understanding your setup here.
Aug 10, 2007 | Onkyo TX-SR604 Receiver
Onkyo TX-SR604 provides audio thru receiver but no video on Bravia LCD when satellite receiver signal is sent thru any of the Onkyo HDMI connections to tv, however if I connect up my Samsung DVD recorder...
easiest fix is to take all hdmi straight to tv. then come out of tv with optical cable to your receiver. that way what ever your watching will automatically be sent to the receiver thru optical. you even will get dolby dig. also you can have audio from your tv when you dont want to use your surround. keeps receiver on one input also.
Jul 02, 2009 | Onkyo TX-SR605 Receiver
Onkyo TX-SR606 aspect ratio issue
you may want to try changing the aspect ratio on the HD box and the DVD as opposed to the receiver. This should do the thing
Mar 04, 2009 | Onkyo TX-SR606 Receiver
What Blu Ray to buy for ONKYO TX-NR801 for Dolby TrueHD, etc???
Hi, as the Onkyo receiver you have does not have HDMI switching, the only thing it will do for you with a Blu-Ray player is process the audio signals.  The video from the BR player will have to go directly to an HDMI input of your hi def TV.  In this case, either Sony or Panasonic BR player will be equal.  Assuming you keep the Onkyo unit you have, you would want to use the optical digital output from the BR player as the audio source into one of the optical, digital audio inputs on the Onkyo.  In an ideal world, your receiver would some that does do HDMI switching.  This way, all the audio and video signals from any audio or video source would be automatically switched and channeled through 1 simple HDMI cable into your hi def TV.  This will make you life simpler as ther would be no need to select an appropriate input on the TV, as well as one on the receiver.  That said, buying a new receiver in addition to a BR player is more costly.  Good luck.  Let us know how it goes.
Jan 02, 2009 | Onkyo TX-NR801 Receiver
No Video only sound with Onkyo TX-SR605 7.1, tried everything, HELP!!!!
hey have a wicked happy birthday... It is mine today too!!! If someone born of Aquarius, on the same day as I cant fix it, then it probably cant be fixed!!
Sounds like you have a faulty receiver, but am going to read the manual as you already have and see if I can add my 2 cents worth... don't give up yet :)
Feb 18, 2008 | Onkyo TX-SR605 Receiver
Distorted HD picture when using Onkyo 605 receiver
use a hdmi switcher and the signal will be spilit up evenly between the two
Jan 02, 2008 | Onkyo TX-SR605 Receiver
Onkyo HT-SR750
Check out Onkyo's website: The HT-SR 800 description says "a separate audio connection is necessary" Maybe it is true for the --750 too.
Jan 01, 2008 | Onkyo TX-SR605 Receiver
Trouble with the hooking up wiring for receiver, DVD/VCR combo and satellite to new DLP TV.
Jar50, lacking model numbers for your TV and Satellite, I would suggest connecting your DTV Satellite OPTICAL out to your 65"DLP. Connect your 65"DLP OPTICAL out to your Onkyo TX-DS484 OPTICAL in. If you are using the DIGITAL COAX, just substitute the instructions above from OPTICAL to COAX.
Hope this helps.
Aug 28, 2017 | Onkyo TX-SR803 Receiver
Onkyo TX-DS474 Receiver Logo
230 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
