Canon PIXMA MP470 All-in-One Printer Logo
Posted on Jul 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon MP470: "Print Head is not installed. Install Print Head"
I have the Canon color and black ink cartridges, and had them refilled. Was working great, but all of sudden I get a message on the LCD that says print head not installed. Won't let me scan, copy, or do anything. Unplugged, removed and re-installed print heads...nothing working
Any help would be great!
Anonymous
Level 3:
Brigadier General:
  • Master 4,088 Answers
  • Posted on Jul 17, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
4088
Questions
0
Helped
1511267
Points
12435
Some printer brands have a cute scheme that reads a "new" cartridge as good, but the refilled one has a small fuse link that is burned out by the printer. Try factory new cartridges. Unplug the printer power for a bit to reset the printer.
David Bergum
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 18, 2017
David Bergum
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5170
Points
In my case, it was a new cartridge that was faulty. When I put the low cartridge back in the error cleared.
My printer keeps saying "print head is not installed. Install the print head." I only purchased black ink this time and I put it inside but it still says that there is no ink. Do I have to buy the colour...
Hello, Jordanreinha -
You will need to install a color cartridge, too.
Oddly enough, with color printers, both the black and color ink/s are used to print black. Go figure?
Best wishes.
2helpful
I'm trying to use the Pixma MP470 printer at work. We haven't used it in perhaps a year b/c we only use it for work-related photos. The screen says, "Print head is not installed. Install the print head." I...
Inkjet printers needs to be used frequently. When not used for three or more months, the head gets clogged and damaged. On your case, per your notes, I believe the printer head needs to be replaced. I don't think it will be cost-effective to repair as a new head printer may be quite expensive. Today printers are cheap to be fixed.
2answers
Canon MP470 prints fine in black and red. But the blue and yellow colors (or comination thereof) will not print out on the page. Ink cartridges are fresh, although, remanufactured ones from Nukote at...
Sometimes the remanufactured cartridges sit around for a time and the ink dries at the print head. Does the ink come out freely when you touch it on a damp paper towel? If not, this may be the fault. To clear the print head, I have heated some water in the microwave for 30 seconds and put just the print head in the hot water for a few seconds. If no microwave, use hottest available tap water. I have used a refill syringe to add a little pressure through the filler hole while in the water to purge the print head. I now refill my own, but have bought the same product and needed to purge them. I have the same printer. If this is not the cure , let me know, we can find the solution.
Refilled ink cartridge wont work. Getting message saying ink is l
Many 'refilled' cartridges aren't refilled. Try a new c artridge and see what happens. If it still doesn't work, you need a new print head.
2answers
Cannon Pixma MP 780
your MCY (color) cartridge is damaged, or either needs cleaning, try to remove this and clean the head with a soft cloth and re-install once again, if it doest work then replace the cartridge
1helpful
5answers
Printer error on a canon mp 470
How I can fix the U051 problem with my conno : MP470 printer ? It says the print head is not installed. Install the print head. Where is the it , and how I can fix it?
please e-mail to [email protected]
2helpful
2answers
Ink cartridge light keeps blinking BEWARE SPAM NUMBER 1-800-532-4187
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
old marine
old marine
ZJ Limited
ZJ Limited
