Question about Garden
Need diagram/instructions on how to replace primer bulb on briggs and stratton push lawn mower My primer bulb has busted so I'm trying to replace. Don't know how to get the old one out and replace.
    Novelist:
  • 109 Answers
Unless they have changed, all you have to do is unscrew the old primer bulb and screw the new one on in it's place. The primer is composed of the rubber bulb with a metal or plastic ring with threads on it where it connects in the fuel system.
Posted on Jul 18, 2009
How to replace lawnmower primer bulb on honda GCV160 engine?
Leo, Did not find your exact model, procedures are usually basically the same. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Primer Bulb Replacement Briggs Stratton Engines
HOW TO Replace Lawnmower Primer Bulb
How to Replace Primer Bulb
May 23, 2016 | Honda Garden
Fuel leaks out of the primer bulb has a nipple with small hole. fuel coming out of the nipple hole. No breaks or tears in the bulb.
ethanol additive in gasoline causes deterioration of fuel system parts, especially primer bulbs. Needs to be replaced...relatively easy for mechanically minded or bring to dealer. Check Amazon for parts...they are cheaper than most dealerships.
Hope this helps....
May 01, 2016 | Briggs & Stratton Briggs Stratton...
Will not prime with primer bulb , can squirt gas in carb and get running then while running you push the primer button it chokes down the engine .
Does it stay running after you squirt fuel in the carb opening? If yes, then there may be a pin hole leak in the hose going from the fuel tank to the primer bulb and it is adding air to your carb.
Thanks
May 01, 2015 | Craftsman 675 Torque 190cc 21" Briggs ...
What is a dry primer bulb on Briggs stratton engine
It is used to bring fuel to the carb before starting. Push it in 5 or 6 times before attempting to start.
Mar 02, 2015 | Briggs & Stratton Garden
My briggs and stratton 158cc 500series push mower primer button melted from sun. how do i replace it?
There is a tab on either side of the carburetor right where the primer bulb sits. You can depress both of these tabs with a screwdriver and pry out the plastic ring that holds the primer bulb in place. You can purchase a new primer bulb (with a new plastic tab) from a local mower shop or from a small engine repair shop. When you install the new primer bulb, put the rubber bulb in first then put the plastic ring on top and press it in until the tabs click on each side. It should work correctly after the tabs are clicked properly. You can take off the air filter and look into the carburetor to see if the unit is priming correctly. I hope this helps you out.
May 09, 2011 | Yard Machines 158cc Push Lawn Mower #11a...
I can get my briggs & stratton push mower to
Your carb needs to by cleaned out. Needs to be taken apart and cleaned with carb cleaner. There is also a gasket that needs to be replaced. It collapsed and not letting gas in the carb.
Jul 07, 2010 | Poulan Pro 22inch 625 Series Briggs ...
Wont start, ran out of petrol ive put petrol in but it wont start ?
If it has the primer bulb push on it many times and try starting again
Jun 14, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Gasket for briggs and stratton
I recommend  Jack's Small Engine Repair; they have always had the detail part I needed and their prices are among the lowest.
They will probably have an illustrated parts page for your model.
Jack's
Mar 22, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Garden Logo
448 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
