Question about All-Pro Forced Air Kerosene Space Heater SPC-K75
Sputters alot Hey there, I just bought a allpro spc-k50 from a yardsale. Fires up but sputters alot, Not sure of fuel conditions nor do I have a manuel to adjust air fuel mix. Any Ideas? Morgan
  • morganj1209 Aug 03, 2009
    I was thinking the same thing, however the tank was full and thought there goes $15.00. I did (with out being able to find or contact a manual) disasemble to find a bad fuel line. Running better now! Still need air / fuel settings and can not seem to find a dealer with a valid phone number or contact? Thank you for assistance and Ideas!! Morgan
    Champion:
  • 363 Answers
Drain the tank and restart with fresh fuel
Posted on Jul 27, 2009
My 1998 tj jeep is hard to start, i replaced fuel pump because the filter had come off the end of it. and replaced the crank position sensor because i got a code po320 It ran fine for a while and then...
try to give it a little more gas it sputters an back fires! In the first place your not giving it more gas unless it running ! If just cranking all your doing is letting more air in . Your vehicle has electronic fuel injection , not a carbuerator . Till the computer see's a RPM over 300 rpm , it's going by programming installed in the PCM - engine computer . It sputters an back fires because of a lean condition , low fuel . When starting a fuel injection engine you don't touch the throttle pedal . And if you were to push it to the floor and hold it , the computer goes into clear flood mode. If the vehicle were flooded that is what you would want to do .
P0320 OBD II Trouble Code
You may have O2 sensor problem or a map sensor or coolant temp . sensor . Your best take it an have a qualifiedd repair shop diagnose it .
Apr 27, 2017 | Cars & Trucks
I have a 02 3.4 chevy impala. my check engine light is on for a bank one o2 sensor. iv replaced the upper and lower o2 sensors twice this week and code is still coming up.also when im driving it feels like...
i would suggest checking fuel pressure and fuel filter could have little dirt or something clogging fuel and engine light will stay on due to too rich or too lean of fuel/air mixture
Oct 08, 2013 | Cars & Trucks
My 2001 buick lesabre is pulling a random misfire code and spits and sputters and smells like the car is floading
find the fuel pressure regulator. you should see it mounted on the return line of the fuel rail under the plastic engine cover. it will have a small vacuum hose attached to it. Remove the hose and see if gas comes out of the regulator. If it does replace it immediately.
Apr 08, 2013 | 2001 Buick LeSabre
I have a 88 chevrolet suburban it sputters when i accelerate
It could be an ignition problem, or low fuel pressure.
If the spark plugs and ignition system are in good condition, I would check fuel pressure and the filter.
If the throttle position sensor is failing, the check engine light should be on.
Feb 25, 2013 | 1988 Chevrolet Suburban
Have a 1989 Buick Skyhawk and it is dying alot and sputters. Changed the fuel filter still won't drive more than a block sputters and dies. Can you recommend a good mechanic in Casper, WY
FIRST CHANGFE YOU TPS (THROTTLE POSITION SENSOR) LOC. ON SIDE OF THE THROTTLE BODY SKYHAWS USUALLY NHAVE THIS PROB. WHEN THE MILIAGE GETS OVER 100,000 MILES.
Aug 14, 2011 | 1989 Buick Skyhawk
My heater ra50a has been sitting for two years got it out and removed all old fuel put in new will nor start. plug fires sputters but will not fire off
Replace the plug or remove and try to clean it. Also, be sure the wire running to the plug is not damaged or dry rotted.
Feb 11, 2011 | Reddy Heating & Cooling
Ford ranger is shacking and sputters when I shut it off.
Have it checked for codes...may be an idle control or EGR issue. If you ran it dry, then you need to change the fuel filter ASAP...the truck is old enough to have sediment in the tank and a clogged filter will stress and damage your fuel pump. Make sure to depressurize the fuel system before pulling the filter to avoid getting a face full of gasoline.
Sep 20, 2009 | 1997 Ford Ranger SuperCab
My 1995 Jetta is running fine without the ac on. After I turn the ac on it may drive fine for a while then all of a sudden it loses alot of power and spits and sputters. What could be the problem. Thanks
make sure your plugs and wires are in good condition.also fuel and air filter.the engine has to be well tuned up.because air conditioner compressor put a little load on engine.if engine is not well tuned.the AC will pull it down.cause it to lose power and run rough.
Jul 25, 2009 | Volkswagen Jetta Cars & Trucks
All-Pro Forced Air Kerosene Space Heater SPC-K75 Logo
349 people viewed this question
Top All-Pro Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
