Garmin GPSMAP 720s TOUCHSCREEN CHARTPLOTTER/FISHFINDER Logo
S
Stiaan du plooy Posted on Jun 22, 2016
On my garmin 720s: when navigating my screen turn all direction i want it to stand still and navigste to a speciffic point. How do i set the screen to srand still?
Murielle Dumas
Level 1:
  • Contributor 35 Answers
  • Posted on Jul 02, 2016
Murielle Dumas
Contributor
Level 1:
Answers
35
Questions
0
Helped
13045
Points
54
Go tools/Settings/Map/Map view/ Track up.
1 Related Answer
Anonymous
  • 32 Answers
  • Posted on Aug 01, 2009
SOURCE: My Garmin 765t stopped navigating
There should be a small reset switch on the back of most garmin gps units. with the unit on, depress the reset switch with a pen tip or small object until the unit shuts off and restarts. It may take a little longer to pick up the satellite but it will reque the unit and unlock the navigation screen.
Turn itself off
Make sure your power cord is solid and not corroded, then try a sofware update, then contact garmin for other options
My Gamin Nuvi can't unlock maps
Use a Garmin 1450
The Garmin Nuvi 1450 can be used while driving or walking.
While driving, use the Nuvi 1450 to create a route to your destination and get step-by-step directions, to hear the names of upcoming streets, to tell you when to change lanes and to find out the speed limits on unfamiliar streets.
As a pedestrian, you can have the Nuvi 1450 create a route for you that uses a mixture of walking and public transportation, such as the subway or bus system, if you have purchased cityXplorer maps for that area.
Tap "Where to?" to set up a route. The "Where to?" icon is a large magnifying glass.
Tap "Addresses." The available categories are address, points of interest, go home, recently found, favorites and intersections.
Input the name of the state or county, if it is out of town.
Then tap "Spell city." Spell out the name of the city using the pop up keyboard.
Press "Done."
Enter the address number and press "Done."
Then enter the street name and press "Done."
The "Go" screen opens automatically.
Tap the green "Go" button. The Nuvi 1450 will now calculate a route to the address.
Follow the voice prompts and map highlight to your destination.
Navigate Using Coordinates
Tap "Where to?" and then tap "Coordinates."
Tap the coordinate you want to adjust/input a new coordinate.
Tap "Format" to choose the right coordinate format for the map you are using.
Enter the coordinates. Tap "Next."
Tap the green "Go" button to calculate a route.
Use the Map Page
Navigate to your destination by following the voice prompts, highlighted route on the map and directions located at the top of the map screen.
Tap the "turn" icon located in the upper left corner of the screen to see the next turn. It may have a turning or straight arrow and the number of miles until the turn. Tap the bar across the top with the next direction listed on it to see a list of all directions.
Tap the plus or minus signs on the right side of the screen to zoom in or out.
Press the spinning arrow in the lower left corner of the screen to return to the main menu.
Tap the "car" icon traveling along the highlighted route to enter the "Where Am I?" screen and get your exact location, coordinates and nearby emergency services.
Hope this helps
Where can I get Egypt maps for Garmin Nuvi 265W?
https://buy.garmin.com/shop/shop.do?pID=72870
Visit Egypt Navigate the streets of Egypt with confidence. City Navigator Egypt NT provides detailed road maps and points of interest for your device, so you can navigate with exact, turn-by-turn directions to any address or intersection. Route to restaurants, gas stations, lodging, attractions and more. Coverage includes major road coverage for Egypt, with metropolitan area coverage of Cairo.
If this solves your problem, please come back and rate our solution, thank you.
Just purchased a Garmin 255W. Works fine if not attached to the car charger. Attached unit to the charge and normal navigation screen disappears. Shouldn't a person be able to drive/navigate and charge...
Hi sudavis70,
yes, you should be able to use your 255w while driving...if its going to the garmin screen ( or the screen with the computer icon) when plugged in to the car charger, then the car charger is probably either bad or not compatible with your unit..if its the original charger, i would buy another one thats made for a garmin.
the only time you shouldn't be able to use your 255w, is when its hooked to your computer.
i fix these and many other gps daily so when considering my advice , please understand i do not google my solutions.
let me know if you need more help or info
bill
Standing Member of G.O.T.
Garmin Nuvi 610- working perfectly then sudden crackling and now loss of sound/or at best crackly and intermiitent sound- but map/navigation and on-screen directions fine
Check the audio output setting on the nuvi. There is a possibility that the FM Transmitter setting has been turned on or that the device has been muted.
To check the audio output setting:
  1. Touch the Speaker icon below the Wrench icon.
  2. At the bottom of the screen, touch Audio Output.
  3. Make sure that the Internal Speaker is selected and touch OK (660, 670, 680, and 5000 models only).
  4. Make sure that the MUTE box does not have a check mark in it. If it does, touch the box to clear the selection.
  5. Make sure the volume level is at a reasonable percent level.
2helpful
Hello everyone. I bought garmin nuvi 750 GPS six months ago. I use it travelling all over and it works pretty good. But I dont know how could i find alternate route for same destination. For eg. I want to...
What you're looking for is called "Via Points" as your friend correctly suggested. From the Garmin Nuvi 750 web based information:
nüvi 750 includes advanced navigational features to take the worry out of traveling. With route planning you can save 10 routes, specify via points and preview simulated turns on the 750's wide screen. In addition, nüvi 750 automatically sorts multiple destinations to provide an efficient route for errands, deliveries or sales calls.
"Alternate routes" are those routes that are created when the nuvi is used with a traffic receiver (FM or MSDN). This allows for a new route to be created with the traffic data so that routes suffering congestion, etc. are avoided. Some people also refer to the routes created when a turn is missed (the GPS indicates "Recalculating") as an "alternate route" but it is not.
3answers
I bought Garmin nuvi 765T after having Viamichelin navigator in my car fo some years. . In the old GPS I could navigate to "city center" which was quite useful, when you travel and want to visit a place...
Check in the settings/setup options to enable all the POIs (Point of Interests) and then check if you can find the "city centers" If not then maybe the maps of this GPS device does not have this POI.
Aug 10, 2009 • Garmin GPS
2answers
2helpful
Hard reset
Hi Friend,
You can't hard-reset it on your own, that can only be done by a Nokia Care Center by flashing the firmware again on the phone.
The phone itself only offers a "soft" reset which only resets the settings.
if you mean a master reset (back to factory settings)
From the stand by screen, select Menu by pressing directly in on the navigation pad.
Scroll to Settings, and select by pressing directly in on the navigation pad.
Scroll to Restore Factory Settings, and select by pressing directly in on the navigation pad.
Enter current Security code and select OK by pressing directly in on the navigation pad.
NOTE: Default Security Code is 12345.
Regards,
Ayyasam
2helpful
New Garmin 330 stuck on kansas
Take the unit outside and turn it on. Then select View Maps, at the top of the screen it will say either "Locating satellites" or "Acquiring Satellites". Once the garmin has locked onto the overhead satellites, then it will say "Ready to Navigate".
Locating Satellites take longer than Acquiring Satellites.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
