Question about Whirlpool Duet GHW9150P Front Load Washer
MILDEW SMELL COMES FROM WASHER - Whirlpool Duet GHW9150P Front Load Washer
    Top Expert:
  • Whirlpool Master
  • 76,164 Answers
. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it run for a minute or two, then stop the cycle, open the lid and slowly add the gallon of hot tap water. Don't overfill — you just want to raise the water level so that it is able to reach and clean the inside top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle. In a couple of minutes, stop it again and just let it sit for at least 30 minutes. Afterward, let the cycle finish, and open the lid to air out the inside.
Posted on Jul 17, 2009
  • 123 Answers
SOURCE: Admiral Washer smells like mildew
You can try cleaning the tub with vinegar and baking soda.
To clean the tub:
This should be done every three months. Set the washing machine on hot, and if there's a setting for extra dirty clothes, choose that. Let the tub fill with water, then add 3 cups of white distilled vinegar and a 1/2 cup of baking soda. When the tub begins to drain, advance the cycle to spin. After the cycle ends, set the washing machine to cold and run another cycle.
Good Luck.
Posted on Apr 10, 2008
Master_Tech
  • 770 Answers
SOURCE: terrible mildew type smell
Water forms in the Bellows it is a rubber boot between the door the drum.. clean this out real well ..To prevent this in the future leave the door cracked open when you are done using the machine to allow it to dry out.
Posted on Aug 25, 2008
jumptrout51
  • 3361 Answers
SOURCE: Maytag Neptune/ clothes smell like mildew
Go out and buy a box of "AFFRESH". Run it according to the directions.
Posted on May 28, 2009
SOURCE: Mildew smell in a Bosch Nexxt Washer
"In recent years, almost all manufacturers started installing drain holes in the bottoms of the gasket to minimize water pooling. When we were comparing models from different manufacturers we noticed that only Bosch had managed to place the drains at the very lowest point within the gasket. Consequently, after each wash, while the gasket is necessarily still wet, there is no pooling of water. Simply leaving the door ajar has all that’s been necessary to avoid the potential odor problem."
Clipped from:
http://www.epinions.com/review/Bosch_Nexxt_500_Plus_Series_WFMC5301UC_27_Front_Load_Washer_with_3_81_cu_ft_Capacity_15_Wash_Cyc/content_441535729284
Posted on Aug 06, 2009
blueextc3221
  • 15935 Answers
SOURCE: washer smell
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 16, 2010
I have a mildew smell within the washer and have
Leave the door open all the time and it will dry out and the mold and smell will subside.
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Mildew smell in washer
there is a chemical you can get to help with the smell from SMELLYWASHER.com
Feb 19, 2010 | Kenmore 22942 Top Load Washer
Odor problems with whirlpool front load washer
Is the smell of mildew?
Run the washer on empty with beach and soap.
This is a common problem when the front door is left closed after use.
When the washer is not in use leave the front door cracked open. This will help in preventing mold & mildew.
Dec 12, 2009 | Whirlpool GHW9100L Front Load Washer
Wet clothes after spin cycle and bad mildew smell. I have seen many complaints about mildew smell with He3 & He4 well really frnt loaders in general. The bad mold is so gross and the smell is horrible.
Clean tub boot the best you can with bleach. Then run an empty load with sunlight automatic dish soap (verry little). Then this should clean and freshin the washer up. The best thing to do is not to shut the door on washer when not in use.
Oct 27, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
What is the sanitation cycle for on Model
Typically "sanitation" cycles require hot water....then they add more heat to the washer during the cycle. It is not 212 degrees, but it is very hot and does kill most germs.
The mildew smell is normally caused by water remaining in the system lines - because the water drain pipe is too high and keeps too much water inside after the system pumps the interior pan. Suggest that you just pour in some bleach after the last load...that should kill all mildew. Please do not overdo it. Only about 1/8th to 1/4 cup is needed to keep the mildew smell under control
Oct 11, 2009 | Washing Machines
May 28, 2009 | Maytag Neptune Washer
Hi, I have a hoover front loading washing machine and inside the drum seal there was a lot of mildew as I accidentally left some damp tea cloths inside the drum and the machine wasn't used for 2 weeks....
Run your washer with 2 cups of bleach, maximum hot water. After it starts agitating for a minute, stop the washer & let it remain for 2 hours. Then continue the wash.
Apr 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Two problems, mildew smell and loud noise in spin cycle
drum bearing failure due to the water seal in front of the bearings failing the smell is probably the grease mixed with water in the outer tub
Jul 15, 2008 | Frigidaire GLTF1240A Front Load Washer
Kenmore washer smells/mildew on rubber
The smell problem is actually because of the softener....its nassssty stuff it coats the interior of the washer and forms a grease like residue. I would use Washer Magic (available at all appliance parts retailers) (only half the container in front loaders) and a hot wash. Also keep spraying the boot with bleach and water soluiton every few hours it will dissappear after awhile. please rate my help
Oct 04, 2007 | Kenmore 44102 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
212 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
